Problems encountered while installing the Deali-Adapter
  • preCICE version
  • Ubuntu 20.04
  • Installation method ( building with CMake)
These are some of the instructions I used to install the deali-Adapter, and I added the last path to the end of HOME/.bashrc
微信截图_20220224110716
In any case, please insert here short errors/output and some context using a code snippet (three ` in the beginning, three ` at the end):
When I ran the example perpendicular-flap /solid-dealii in the tutorials, he reported the following error.
--     . running with 16 threads
--     . adapter revision 005933d on branch master
--     . deal.II 10.0.0-pre (revision ab6cf4896a on branch master)
(0) 13:32:30 [xml::XMLParser]:152 in readXmlFile: ERROR: XML parser was unable to open configuration file "precice-config.xml"
Thank you!
How and from which directory do you start the deal.II solver? It mainly complains that it cannot find the preCICE configuration file so I assume you start the solver form a different directory than expected.
Thanks for your reply. I have replaced dealii with Calculix and installed successfully.
