A question about dealii-adapter recompilation
After I made the changes to the nonlinear solver in dealii-adapter, I was ready to recompile the executable in dealii-adapter using cmake again, and the following error message appeared in the terminal:
-- Using the deal.II-9.5.1 installation found at /home/cj123/Dealii-9.5.1
-- Include macro /home/cj123/Dealii-9.5.1/share/deal.II/macros/macro_deal_ii_add_test.cmake
-- Include macro /home/cj123/Dealii-9.5.1/share/deal.II/macros/macro_deal_ii_initialize_cached_variables.cmake
-- Include macro /home/cj123/Dealii-9.5.1/share/deal.II/macros/macro_deal_ii_invoke_autopilot.cmake
-- Include macro /home/cj123/Dealii-9.5.1/share/deal.II/macros/macro_deal_ii_pickup_tests.cmake
-- Include macro /home/cj123/Dealii-9.5.1/share/deal.II/macros/macro_deal_ii_query_git_information.cmake
-- Include macro /home/cj123/Dealii-9.5.1/share/deal.II/macros/macro_deal_ii_setup_target.cmake
-- Include macro /home/cj123/Dealii-9.5.1/share/deal.II/macros/macro_shell_escape_option_groups.cmake
-- Include macro /home/cj123/Dealii-9.5.1/share/deal.II/macros/macro_target_compile_flags.cmake
-- Include macro /home/cj123/Dealii-9.5.1/share/deal.II/macros/macro_target_link_flags.cmake
-- Query git repository information.
-- Using the preCICE version found at /usr/lib/x86_64-linux-gnu/cmake/precice
-- Configuring done
CMake Error in CMakeLists.txt:
  Imported target "precice::precice" includes non-existent path
    "/usr/include/precice"
  in its INTERFACE_INCLUDE_DIRECTORIES.  Possible reasons include:
  * The path was deleted, renamed, or moved to another location.
  * An install or uninstall procedure did not complete successfully.
  * The installation package was faulty and references files it does not
  provide.
  provide.
-- Generating done
CMake Generate step failed.  Build files cannot be regenerated correctly.
I don’t know how to fix it? Does it need to be reinstalled or something else? I hope to get help from you guys.
How did you install preCICE?
I assume that you installed it from source. Did you configure the installation prefix? Building from source - Preparation | preCICE - The Coupling Library
You can also make your preCICE installation discoverable from the build directory: Building from source - Finding | preCICE - The Coupling Library
Thank you for the help you have provided. I had a problem with my environment variable configuration, which has now been resolved
