Body:
When I try to build the preCICE adapter for OpenFOAM v9, I encounter the following error during the OpenFOAM9 / ./Allwmake step:
Interface.C:218:14: error: ‘map’ is not a member of ‘std’
218 | std::map<std::tuple<double, double, double>, int> verticesMap;
Interface.C:5:1: note: ‘std::map’ is defined in header ‘<map>’; did you forget to ‘#include <map>’?
4 | #include "cellSet.H"
+++ |+#include <map>
5 |
Interface.C:218:52: error: expected primary-expression before ‘,’ token
Interface.C:218:54: error: expected primary-expression before ‘int’
Interface.C:262:17: error: ‘verticesMap’ was not declared in this scope; did you mean ‘vertices’?
262 | verticesMap.emplace(std::make_tuple(vertices[3 * i], vertices[3 * i + 1], vertices[3 * i + 2]), vertexIDs_[i]);
| vertices
Interface.C:306:21: error: ‘triEngine’ was not declared in this scope
306 | triEngine.triangulate(UIndirectList<point>(pointCoords, faceQuad));
Interface.C:314:50: error: ‘verticesMap’ was not declared in this scope; did you mean ‘vertices’?
314 | triVertIDs.push_back(verticesMap.at(std::make_tuple(pointCoords[triEngine.triPoints()[triIndex][nodeIndex]][0], pointCoords[triEngine.triPoints()[triIndex][nodeIndex]][1], pointCoords[triEngine.triPoints()[triIndex][nodeIndex]][2])));
| vertices
make: *** [/opt/openfoam9/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/Interface.o] Error 1
=== ERROR: Building failed. See wmake.log for more. ===
I’m not sure what caused this. Could it be due to an incompatible version between preCICE (v3.2.0) and the OpenFOAM v9 adapter?
Here is some information about my environment:
OpenFOAM version: 9
preCICE version: 3.2.0
Operating system: Ubuntu 22.04
Installation method: Installed via
install -
Experience level: I’m a beginner with OpenFOAM and preCICE
Any suggestions or guidance would be greatly appreciated. Thank you!
