preCICE installation - OpenFOAM adapter
I am trying to install the Open FOAM adapter for preCICE. I have the latest versions of OpenFOAM 12.0 and preCICE 3.2 installed. but it gives me the following error when I run the AllWmake file, based on this documentation.
https://precice.org/adapter-openfoam-get.html
cfd@MIC-WK-CFD3:~/openfoam-adapter$ ./Allwmake
Building the OpenFOAM-preCICE adapter...
If not already known by the system, preCICE may be located using:
  pkg-config --cflags libprecice  = -I/usr/local/include
  pkg-config --libs libprecice    = -L/usr/local/lib -lprecice
Current OpenFOAM environment:
  WM_PROJECT = OpenFOAM
  WM_PROJECT_VERSION = 12
  WM_NCOMPPROCS = 1 (number of threads for parallel builds)
The adapter will be built into /home/cfd/OpenFOAM/cfd-12/platforms/linux64GccDPInt32Opt/lib
Additional preprocessor/compiler options:
wmake libso .
wmakeLnIncludeAll: running wmakeLnInclude on dependent libraries:
    wmakeLnInclude error: base directory /opt/openfoam12/src/transportModels/incompressible/ does not exist
    wmakeLnInclude error: base directory /opt/openfoam12/src/transportModels/compressible/ does not exist
    wmakeLnInclude error: base directory /opt/openfoam12/src/transportModels/twoPhaseMixture/ does not exist
    wmakeLnInclude error: base directory /opt/openfoam12/src/transportModels/interfaceProperties/ does not exist
    wmakeLnInclude error: base directory /opt/openfoam12/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/ does not exist
    wmakeLnInclude error: base directory /opt/openfoam12/src/TurbulenceModels/turbulenceModels/ does not exist
    wmakeLnInclude error: base directory /opt/openfoam12/src/TurbulenceModels/compressible/ does not exist
    wmakeLnInclude error: base directory /opt/openfoam12/src/TurbulenceModels/incompressible/ does not exist
g++ -std=c++14 -m64 -DLIB_NAME=libpreciceAdapterFunctionObject.so -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam12/src/finiteVolume/lnInclude -I/opt/openfoam12/src/meshTools/lnInclude -I/opt/openfoam12/src/transportModels/ -I/opt/openfoam12/src/transportModels/incompressible/lnInclude -I/opt/openfoam12/src/transportModels/compressible/lnInclude -I/opt/openfoam12/src/transportModels/twoPhaseMixture/lnInclude -I/opt/openfoam12/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam12/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/opt/openfoam12/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam12/src/TurbulenceModels/turbulenceModels/lnInclude -I/opt/openfoam12/src/TurbulenceModels/compressible/lnInclude -I/opt/openfoam12/src/TurbulenceModels/incompressible/lnInclude -I/opt/openfoam12/src/triSurface/lnInclude -I/usr/local/include  -I../  -IlnInclude -I. -I/opt/openfoam12/src/OpenFOAM/lnInclude -I/opt/openfoam12/src/OSspecific/POSIX/lnInclude   -fPIC -c Interface.C -o Make/linux64GccDPInt32Opt/Interface.o
In file included from Interface.C:4:
Interface.H:6:10: fatal error: fvCFD.H: No such file or directory
    6 | #include "fvCFD.H"
compilation terminated.
make: *** [/opt/openfoam12/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/Interface.o] Error 1
=== ERROR: Building failed. See wmake.log for more. ===
Possible causes:
- Make sure you are using a compatible version of the adapter for your OpenFOAM version:
  https://precice.org/adapter-openfoam-support.html
- Is preCICE discoverable at compile time? Check the content of ADAPTER_PKG_CONFIG_CFLAGS above.
Attach your Allwmake.log and wmake.log when asking for help.
i have openfoam installed here
cfd@MIC-WK-CFD3:/opt/openfoam12$ ls
Allwmake  COPYING  README.org  applications  bin  build-stamp  doc  etc  platforms  src  test  thirdparty  tutorials  wmake
Also my current openfoam installation doesn’t contain the transportModels folder as mentioned in the error.
cfd@MIC-WK-CFD3:/$ ls -d /opt/openfoam12/src/*/
/opt/openfoam12/src/MomentumTransportModels/        /opt/openfoam12/src/fvConstraints/       /opt/openfoam12/src/parallel/
/opt/openfoam12/src/ODE/                            /opt/openfoam12/src/fvMeshDistributors/  /opt/openfoam12/src/physicalProperties/
/opt/openfoam12/src/OSspecific/                     /opt/openfoam12/src/fvMeshMovers/        /opt/openfoam12/src/polyTopoChange/
/opt/openfoam12/src/OpenFOAM/                       /opt/openfoam12/src/fvMeshStitchers/     /opt/openfoam12/src/radiationModels/
/opt/openfoam12/src/Pstream/                        /opt/openfoam12/src/fvMeshTopoChangers/  /opt/openfoam12/src/randomProcesses/
/opt/openfoam12/src/ThermophysicalTransportModels/  /opt/openfoam12/src/fvModels/            /opt/openfoam12/src/renumber/
/opt/openfoam12/src/atmosphericModels/              /opt/openfoam12/src/fvMotionSolver/      /opt/openfoam12/src/rigidBodyMotion/
/opt/openfoam12/src/combustionModels/               /opt/openfoam12/src/generic/             /opt/openfoam12/src/sampling/
/opt/openfoam12/src/conversion/                     /opt/openfoam12/src/lagrangian/          /opt/openfoam12/src/specieTransfer/
/opt/openfoam12/src/dummyThirdParty/                /opt/openfoam12/src/mesh/                /opt/openfoam12/src/surfMesh/
/opt/openfoam12/src/fileFormats/                    /opt/openfoam12/src/meshCheck/           /opt/openfoam12/src/thermophysicalModels/
/opt/openfoam12/src/finiteVolume/                   /opt/openfoam12/src/meshTools/           /opt/openfoam12/src/triSurface/
/opt/openfoam12/src/functionObjects/                /opt/openfoam12/src/motionSolvers/       /opt/openfoam12/src/twoPhaseModels/
/opt/openfoam12/src/fvAgglomerationMethods/         /opt/openfoam12/src/multiphaseModels/    /opt/openfoam12/src/waves/
wmake.log (2.4 KB)
We don’t yet support recent OpenFOAM.org versions in the latest version of the adapter. I am occasionally working on porting, but we are generally focusing on OpenFOAM.com because it is easier to keep track of.
Find the latest state in the documentation: OpenFOAM support | preCICE - The Coupling Library
Eventually, ported versions will be available in this repository: GitHub - precice/openfoam-org-adapter: OpenFOAM-preCICE adapter fork for OpenFOAM Foundation versions (work in progress)
Thanks! @Makis for highlighting the difference. I reinstalled the new version, and it worked correctly. Although I am facing issues for running the perpendicular-flap tutorial. I will open a separate issue for that.
