Due to the use of CentOS 7 system in the cluster, only precice v2.3.0 supports this system. So I want to know, I am using openfoam-adapter v1.3.1 for Openfoam 2312. Are there compatibility issues between these software packages? Because I failed to compile openFoam-adapter after compiling OpenFOAM-v2312.
Jia-Yu
The OpenFOAM adapter v1.3.0 and later only works with preCICE v3.
For preCICE v2, you can use the adapter v1.2.3 or earlier.
