When I try to run my case I found the following error
ERROR: Only thermal coupling or FSI is available with preCICE
Can someone of you help me?
this seems to come from the CalculiX Adapter and probably occurs because you chose some wrong simulation type for CalculiX. Can you give more information on your case and maybe attach the CalculiX input file?
I can really solve it thank you.
