Hello everyone,
I want to do a steady-state FSI simulation using OpenFOAM and CalculiX. Currently the CalculiX adapter only allows a “DYNAMIC” step for FSI. Whereas for doing a steady-state FSI, I need to use a “STATIC” step in CalculiX.
So, what changes need to be made to implement this new feature where the CalculiX adapter allows a “STATIC” step as well ?
@mattfrei ,As you have some ideas on this, can you please share them here ?
Hi @Rahul_dev_meher
we can try to figure out a solution for using the “STATIC” step and working with the CalculiX-Adapter. What happens if you use the keyword now in your FSI case setup? If you already have a case setup and have tried this, then please open an issue in the adapter repository. Once you provide more information in the issue, a discussion would be much easier.
Thanks @IshaanDesai
If I use the keyword “STATIC” in CalculiX input file, the following error is shown in Solid.log - " ERROR: Only thermal coupling or FSI is available with preCICE "
I will open an issue in the adapter repository.
