preCICE version: libprecice2_2.3.0_focal.deb
Operating system or platform: Ubuntu 22.04
Installation method:
Getting and installing precice
wget https://github.com/precice/precice/releases/download/v2.3.0/libprecice2_2.3.0_focal.deb
sudo apt install ./libprecice2_2.3.0_focal.deb
installingOF
wget -q -O - https://dl.openfoam.com/add-debian-repo.sh | sudo bash
sudo apt install openfoam2112-dev
echo "source /usr/lib/openfoam/openfoam2112/etc/bashrc" >> ~/.bashrc
source ~/.bashrc
Installing dependencies
sudo apt install build-essential pkg-config cmake git
Download and install OF-precice adapter
git clone --branch=master --depth 1 https://github.com/precice/openfoam-adapter
cd openfoam-adapter
./Allwmake
Dependency versions: openfoam8
Makis
October 14, 2023, 9:26pm
2
Hi! Did you maybe try to install the adapter with a different version of OpenFOAM before? Try running ./Allclean first, before running ./Allwmake again.
Hi, what should I do if this happens, thanks!
Makis
October 15, 2023, 9:12am
4
Can you please upload your ldd.log?
ldd.log (24.2 KB)
Hello, the file is as follows
Makis
October 17, 2023, 11:21am
6
At the bottom of this file, there are several undefined symbols reported, all related to preCICE dependencies.
Have you installed the dependencies of preCICE as well? Are they loaded/accessible at the moment you are trying to build the OpenFOAM adapter?
6tang12
October 17, 2023, 12:08pm
7
Hello, I have precice 2.4 installed, what are the dependencies you are referring to?
Makis
October 18, 2023, 1:15pm
9
These are the dependencies: Building from source - Dependencies | preCICE - The Coupling Library (Boost, libxml2, mpi, …).
In your first post, you wrote that you installed preCICE 2.3.0, but in your latest post, I see preCICE 2.4.0. Could it be that you have both installed?
Does the cpp-solid participant of the Quickstart run? That one does not depend on OpenFOAM.
6tang12
October 22, 2023, 2:42am
10
Hello, I just installed version 2.4, do I need to install and compile these dependencies by myself?
Makis
October 22, 2023, 7:58am
11
When you do
sudo apt install ./libprecice2_2.4.0_focal.deb
it should install the dependencies by itself.
I assume that you have run the following at some point recently, to get updates in your system:
sudo apt update
sudo apt upgrade
6tang12
October 22, 2023, 9:18am
12
Hi, I have repeated this and it still shows the above error, what should I do at this point?
Makis
October 23, 2023, 2:02pm
13
Looking back at your first post, this is the problem
6tang12:
preCICE version: libprecice2_2.3.0 _focal .deb
These are the ubuntu release codenames :
Ubuntu 20.04: Focal Fossa
Ubuntu 22.04: Jammy Jellyfish
You are downloading the wrong Debian package for your Ubuntu version. Since you are on Ubuntu 22.04, try downloading the _jammy packages, and it should just work.
P.S.: I know that using codenames is confusing, but unfortunately this is how Ubuntu does it.
