Hi there,
Recently I have tried to install precice, openfoam, and the openfoam-adapter in a debian subsystem on my windows 10 laptop. Following the quick guide worked up to the point where I want to run the ./Allwmake command in the openfoam-adapter directory.
When trying to build the adapter, it first shows an error saying:
Building the OpenFOAM-preCICE adapter...
If not already known by the system, preCICE may be located using:
pkg-config --cflags libprecice =
pkg-config --libs libprecice = -lprecice
Current OpenFOAM environment:
WM_PROJECT =
WM_PROJECT_VERSION =
WM_NCOMPPROCS = 1 (number of threads for parallel builds)
=== ERROR: It looks like no OpenFOAM environment is available. ===
Possible reasons:
- Have you loaded the OpenFOAM etc/bashrc file?
- Are you using a compatible OpenFOAM version?
See https://www.precice.org/adapter-openfoam-support.html
I then try to load the bashrc file with source /lib/openfoam/openfoam2306/etc/bashrc, which then changes my ./Allwmake output to:
WM_PROJECT = OpenFOAM
WM_PROJECT_VERSION = v2306
The adapter will be built into /home/falco/OpenFOAM/falco-v2306/platforms/linux64GccDPInt32Opt/lib
Additional preprocessor/compiler options:
wmake libso (openfoam-adapter)
Everything looks fine in wmake.log.
Possible causes:
- Is preCICE discoverable at runtime? Check the content of pkg-config output above.
- Did anything go wrong while installing preCICE? Can you run any other preCICE tutorials?
- Did anything go wrong while installing OpenFOAM? Can you run any other OpenFOAM tutorials?
Attach your Allwmake.log, wmake.log, and ldd.log when asking for help.
I have added my Allwmake.log and ldd.log files from this last run to this post.
Allwmake.log (6.6 KB)
ldd.log (15.9 KB)
