Make issues installing precice
Hi! I am having issues with installing precice. I am following the quickstart guide (Quickstart | preCICE - The Coupling Library), and am running into make errors when getting to step 4, line 4.
Please describe your system, and especially:
  • preCICE version: 3.1.1
  • Operating system or platform: Ubuntu 22.04, x86_64
  • Installation method: cmake, it looks like
  • Dependency versions: not sure, openfoam 2406-dev
I receive the following output when executing make:
Building the OpenFOAM-preCICE adapter…
If not already known by the system, preCICE may be located using:
pkg-config --cflags libprecice =
pkg-config --libs libprecice = -lprecice
Current OpenFOAM environment:
WM_PROJECT = OpenFOAM
WM_PROJECT_VERSION = v2406
WM_NCOMPPROCS = 1 (number of threads for parallel builds)
The adapter will be built into /home//OpenFOAM/-v2406/platforms/linux64GccDPInt32Opt/lib
Additional preprocessor/compiler options:
Building with WMake (see the wmake.log log file)…
wmake libso (openfoam-adapter-1.3.1)
Everything looks fine in wmake.log.
Possible causes:
  • Is preCICE discoverable at runtime? Check the content of pkg-config output above.
  • Did anything go wrong while installing preCICE? Can you run any other preCICE tutorials?
  • Did anything go wrong while installing OpenFOAM? Can you run any other OpenFOAM tutorials?
    Attach your Allwmake.log, wmake.log, and ldd.log when asking for help.
There appears to be a host of packages and such that it is not able to find from the above troubleshooting commands. I can find OpenFOAM, although I have another version of it removed from .bashrc on my system, since I was runnning tutorials on that one.
Attached are the log files that may help.
Allwmake.log (6.3 KB)
wmake.log (37 Bytes)
ldd.log (18.8 KB)
Thanks!
Did you maybe install preCICE using a Debian package for the wrong Ubuntu version?
At the bottom of your ldd.log, I see a few undefined symbols for several dependencies (Boost, PETSc, …), which could be explained by this.
Ah, you are right. I have Ubuntu 24.04, not 22.04. Not sure why I didn’t notice this earlier.
