Problem linking adapted CalculiX against yaml-cpp (macOS)
Dear preCICE community,
I tried to build the adapted CalculiX on macOS. I successfully built CalculiX itself, but for some bizarre reason, it complains that it cannot link with yaml-cpp.
Here’s the output of the command:
mpif90 -fopenmp -Wall -O3 -o bin/ccx_preCICE bin/ccx_2.20.o bin/ccx_2.20.a /Volumes/SourceCode/software/CalculiX/ccx_2.20/ThirdParty/SPOOLES.2.2/spooles.a /Volumes/SourceCode/software/CalculiX/ccx_2.20/ThirdParty/SPOOLES.2.2/MT/src/spoolesMT.a -L/Users/ali/.local/lib -lprecice `pkg-config --libs yaml-cpp` -lstdc++ -L/opt/homebrew/Cellar/arpack/3.9.1_1/lib -larpack -llapack -lblas -lpthread -lm -lc
Undefined symbols for architecture arm64:
  "YAML::detail::node_data::set_scalar(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char>> const&)", referenced from:
      YAML::detail::node& YAML::detail::node::get<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char>>>(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char>> const&, std::shared_ptr<YAML::detail::memory_holder>) in ccx_2.20.a[1123](ConfigReader.o)
      YAML::detail::node& YAML::detail::node_data::get<int>(int const&, std::shared_ptr<YAML::detail::memory_holder>) in ccx_2.20.a[1123](ConfigReader.o)
  "YAML::detail::node_data::convert_to_map(std::shared_ptr<YAML::detail::memory_holder>)", referenced from:
  "YAML::LoadFile(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char>> const&)", referenced from:
      _ConfigReader_Read in ccx_2.20.a[1123](ConfigReader.o)
ld: symbol(s) not found for architecture arm64
I tried using two different versions of yaml-cpp, but neither worked. The path to the header files and libraries was correct, as determined by pkg-config --libs yaml-cpp. Using LSP, I can jump to the declarations in the header files. Also, the shared library contains all these symbols, which I confirmed using nm -C /path/to/lib | grep symbolName. I also tried to put the link flag -lyaml-cpp at different orders, but it too didn’t help.
At this point, I’m not sure what I’m missing. I would greatly appreciate it if anyone could help me identify the issue.
System and tools information:
  • CalculiX: 2.20 (Using the one mentioned in the preCICE documentation)
  • Adapted CalculiX: The one that is currently mentioned in the docs (probably 2.20)
  • preCICE: v3.1.2
  • Operating system: macOS Sonoma 14.7.1
  • Installation method: Compilation from source
  • Dependency versions:
    • Homebrew GCC 14.2.0
    • Homebrew Clang 19.1.2
    • Open MPI: stable 5.0.6
    • PETSc: stable 3.22.2
    • yaml-cpp:
      • 0.8.0 (Homebrew)
      • 0.6.0 (built from source)
I vaguely remember similar issues many years ago with older GCC versions, on older systems. I think the main issue was that std::string had a breaking ABI change in C++11.
What is the default C++ standard assumed by your compiler? What happens if you set -std=c++11?
And… did you in the meantime manage to resolve this issue?
Thanks for your reply.
I compiled everything in C++1: precice (-DCMAKE_CXX_STANDARD=11), yaml-cpp (-DCMAKE_CXX_STANDARD=11), and also passed -std=c++11 in the adaptor’s makefile. So far, no luck.
Note that I had to add these flags to CFLAGS as well: -Wno-implicit-function-declaration -Wno-incompatible-pointer-types.
Thanks for the reports!
I guess a reasonable next step would be to find out if you can link a minimal yaml-cpp example to yaml-cpp, independent of CalculiX and preCICE. There are some examples here: Tutorial · jbeder/yaml-cpp Wiki · GitHub
Aha. It only links with clang++. So, I used clang++ and linked with libc++ instead of libstdc++ and the adaptor linked against libyaml-cpp without any error. If you like, I can send a patch or a PR.
As we’re here, I want to also mention that in “Breaking dam with flexible pillar 2D” example, I get the following error for the solid case:
$ ./run.sh
Started on: Sun, 30 Mar 2025 06:22:49 +0330
CalculiX Version 2.20, Copyright(C) 1998-2022 Guido Dhondt
CalculiX comes with ABSOLUTELY NO WARRANTY. This is free
software, and you are welcome to redistribute it under
certain conditions, see gpl.htm
You are using an executable made on Sun Jul 31 18:08:37 CEST 2022
  The numbers below are estimated upper bounds
  number of:
   nodes:         1470
   elements:          244
   one-dimensional elements:            0
   two-dimensional elements:            0
   integration points per element:           27
   degrees of freedom per node:            3
   layers per element:            1
   distributed facial loads:            0
   distributed volumetric loads:            0
   concentrated loads:         1482
   single point constraints:          756
   multiple point constraints:            1
   terms in all multiple point constraints:            1
   tie constraints:            0
   dependent nodes tied by cyclic constraints:            0
   dependent nodes in pre-tension constraints:            0
   sets:            4
   terms in all sets:         2220
   materials:            1
   constants per material and temperature:            2
   temperature points per material:            1
   plastic data points per material:            0
   orientations:            0
   amplitudes:            3
   data points in all amplitudes:            3
   print requests:            0
   transformations:            0
   property cards:            0
 *INFO reading *STEP: nonlinear geometric
       effects are turned on
 STEP            1
 Dynamic analysis was selected
 Newton-Raphson iterative procedure is active
 Nonlinear geometric effects are taken into account
 Decascading the MPC's
 Determining the structure of the matrix:
 Using up to 1 cpu(s) for setting up the structure of the matrix.
 number of equations
 3660
 number of nonzero lower triangular matrix elements
 63428
Starting FSI analysis via preCICE using the geometrically non-linear CalculiX solver...
 Using up to 1 cpu(s) for the energy calculation.
 Using up to 1 cpu(s) for spooles.
[temple.local:59980] shmem: mmap: an error occurred while determining whether or not /var/folders/1t/mjqc57nd6jq91gb0_jb143w80000gn/T//ompi.temple.501/jf.0/2796027904/sm_segment.temple.501.a6a80000.0 could be created.
---[precice]  This is preCICE version 3.1.2
---[precice]  Revision info: v3.1.2-299-gfc0cff1b
---[precice]  Working directory "/Volumes/code/opt/precice/tutorials/breaking-dam-2d/solid-calculix"
---[precice]  I am participant "Solid"
Using quasi 2D-3D coupling
Set ID Found
2D-3D mapping results in a 2D mesh of size 247 from the 494 points in 3D space.
Read data 'Force' found.
Write data 'Displacement' found.
Specifically this one:
and then simulation is stuck here
With printf-debugging I found out that it happens here:
  printf("Setting up preCICE participant %s, using config file: %s\n", participantName, configFilename);
  fflush(stdout);   <<<
from adapter/PreciceInterface.c.
LLM suggested passing --mca shmem mmap to mpirun; I edited the run.sh per below and that fixed the shmem error.
mpirun -np 1 --mca shmem mmap ccx_preCICE -i flap -precice-participant Solid
However, still the simulation is stuck at the last line I mentioned. I’m not sure whether that’s the intended behaviour.
Yes, please, submit a PR (or two, for the second issue) if you can, that would be great! :hugs:
Let’s continue the discussion in a new topic for each new problem.
