This issue is related to this discussion. The following is the continuation of that discussion.
I built calculix adapter on macos with some modifications to the Makefile. I opened a pull request here.
In “Breaking dam with flexible pillar 2D” example, I get the following error for the solid case:
$ ./run.sh
Started on: Sun, 30 Mar 2025 06:22:49 +0330
CalculiX Version 2.20, Copyright(C) 1998-2022 Guido Dhondt
CalculiX comes with ABSOLUTELY NO WARRANTY. This is free
software, and you are welcome to redistribute it under
certain conditions, see gpl.htm
You are using an executable made on Sun Jul 31 18:08:37 CEST 2022
The numbers below are estimated upper bounds
number of:
nodes: 1470
elements: 244
one-dimensional elements: 0
two-dimensional elements: 0
integration points per element: 27
degrees of freedom per node: 3
layers per element: 1
distributed facial loads: 0
distributed volumetric loads: 0
concentrated loads: 1482
single point constraints: 756
multiple point constraints: 1
terms in all multiple point constraints: 1
tie constraints: 0
dependent nodes tied by cyclic constraints: 0
dependent nodes in pre-tension constraints: 0
sets: 4
terms in all sets: 2220
materials: 1
constants per material and temperature: 2
temperature points per material: 1
plastic data points per material: 0
orientations: 0
amplitudes: 3
data points in all amplitudes: 3
print requests: 0
transformations: 0
property cards: 0
*INFO reading *STEP: nonlinear geometric
effects are turned on
STEP 1
Dynamic analysis was selected
Newton-Raphson iterative procedure is active
Nonlinear geometric effects are taken into account
Decascading the MPC's
Determining the structure of the matrix:
Using up to 1 cpu(s) for setting up the structure of the matrix.
number of equations
3660
number of nonzero lower triangular matrix elements
63428
Starting FSI analysis via preCICE using the geometrically non-linear CalculiX solver...
Using up to 1 cpu(s) for the energy calculation.
Using up to 1 cpu(s) for spooles.
[temple.local:59980] shmem: mmap: an error occurred while determining whether or not /var/folders/1t/mjqc57nd6jq91gb0_jb143w80000gn/T//ompi.temple.501/jf.0/2796027904/sm_segment.temple.501.a6a80000.0 could be created.
---[precice] This is preCICE version 3.1.2
---[precice] Revision info: v3.1.2-299-gfc0cff1b
---[precice] Build type: Release (without debug log)
---[precice] Working directory "/Volumes/code/opt/precice/tutorials/breaking-dam-2d/solid-calculix"
---[precice] Configuring preCICE with configuration "../precice-config.xml"
---[precice] I am participant "Solid"
Using quasi 2D-3D coupling
Set ID Found
2D-3D mapping results in a 2D mesh of size 247 from the 494 points in 3D space.
Read data 'Force' found.
Write data 'Displacement' found.
---[precice] Setting up primary communication to coupling partner/s
Specifically this one:
and then simulation is stuck here
With printf-debugging I found out that it happens here:
printf("Setting up preCICE participant %s, using config file: %s\n", participantName, configFilename);
fflush(stdout); <<<
from adapter/PreciceInterface.c.
LLM suggested passing --mca shmem mmap to mpirun; I edited the run.sh per below and that fixed the shmem error.
mpirun -np 1 --mca shmem mmap ccx_preCICE -i flap -precice-participant Solid
However, still the simulation is stuck at the last line I mentioned. I’m not sure whether that’s the intended behaviour.
