Abnormal deformation of the object mesh
I’m currently using overlapping grids to test a floating object, but only half of it is moving, and I’m seeing the jagged edges shown in the image. How can I fix this?
My model is a hexagonal floating block. I used the nearest-projection mapping method.
I suggest enabling exports in both preCICE participants and visualizing the provided meshes together in Paraview.
This is a reliable way to check if both solvers use the same coordinate system when exposing their meshes. This also allows you to inspect if the displacements look correct.
