In above picture, I’ve plotted the actual recieved values vs the precice-exported values side-by-side for ease of comparison. These sphere points are the nodes of the target patch. Weired random values seemed to be exported by precice. The mapping method is direct-mesh-access write.
To be specific, the data plotted is UWind on OpenFOAM-NearReadPatch-Mesh1:
exchange data=“UWind” mesh=“OpenFOAM-NearReadPatch-Mesh1” from=“OpenFOAM-Wind1” to=“OpenFOAM1” initialize=“0”
In another picture above, I’ve plotted the precice-exported values on a source mesh from which the just-in-time read is performed. Weired random values again. I wonder if this is a known issue for a precice-exported mesh where api-access=“true”?
The data plotted is UNear on OpenFOAM-Relaxation-Mesh1:
exchange data=“UNear” mesh=“OpenFOAM-Relaxation-Mesh1” from=“OpenFOAM1” to=“OpenFOAM-Wind1” initialize=“0”
<precice-configuration experimental="true">
<log>
<sink
enabled="true" />
</log>
<!-- wind<->HOS coupling data -->
<data:scalar name="etaHOS" waveform-degree="1" />
<data:scalar name="pWind" waveform-degree="1" />
<!-- wind<->near coupling data -->
<data:vector name="UWind" waveform-degree="1" />
<data:vector name="UNear" waveform-degree="1" />
<data:scalar name="p_rgh" waveform-degree="1" />
<!-- near<->HOS coupling data -->
<data:vector name="UHOS" waveform-degree="1" />
<data:scalar name="etaVOF" waveform-degree="1" />
<data:scalar name="etaShifted" waveform-degree="1" />
<data:scalar name="wVOF" waveform-degree="1" />
<data:scalar name="weights" waveform-degree="1" />
<!-- wind<->HOS coupling meshes -->
<mesh name="Wind-Coupling-Mesh1" dimensions="3">
<use-data name="etaHOS" />
<use-data name="pWind" />
</mesh>
<mesh name="HOS-Wind-Mesh1" dimensions="3">
</mesh>
<!-- wind<->near coupling meshes -->
<!-- wind side has no meshes since JIT-read and DMA-write -->
<!-- near side see OpenFOAM-Relaxation-Mesh1 and OpenFOAM-Central-Mesh1 below -->
<!-- near<->HOS coupling meshes -->
<mesh name="HOS-Relaxation-Mesh1" dimensions="2">
<use-data name="UHOS" />
</mesh>
<mesh name="HOS-Coupling-Mesh1" dimensions="2">
<use-data name="etaVOF" />
<use-data name="etaShifted" />
<use-data name="wVOF" />
<use-data name="weights" />
</mesh>
<mesh name="OpenFOAM-Relaxation-Mesh1" dimensions="2">
<use-data name="UNear" />
<use-data name="p_rgh" />
</mesh>
<mesh name="OpenFOAM-Central-Mesh1" dimensions="2">
</mesh>
<mesh name="OpenFOAM-Coupling-Mesh1" dimensions="2">
</mesh>
<mesh name="OpenFOAM-NearReadPatch-Mesh1" dimensions="2">
<use-data name="UWind" />
</mesh>
<participant name="OpenFOAM-Wind1">
<!-- wind<->HOS -->
<provide-mesh name="Wind-Coupling-Mesh1" />
<receive-mesh name="HOS-Wind-Mesh1" from="HOS-Coupling" />
<read-data name="etaHOS" mesh="Wind-Coupling-Mesh1" />
<write-data name="pWind" mesh="Wind-Coupling-Mesh1" />
<mapping:linear-cell-interpolation direction="read" from="HOS-Wind-Mesh1" to="Wind-Coupling-Mesh1" constraint="consistent" />
<export:vtu directory="precice-exports" every-n-time-windows="100" />
<!-- wind<->near -->
<receive-mesh name="OpenFOAM-Relaxation-Mesh1" from="OpenFOAM1" api-access="true" />
<receive-mesh name="OpenFOAM-NearReadPatch-Mesh1" from="OpenFOAM1" api-access="true" />
<read-data name="p_rgh" mesh="OpenFOAM-Relaxation-Mesh1" />
<read-data name="UNear" mesh="OpenFOAM-Relaxation-Mesh1" />
<write-data name="p_rgh" mesh="OpenFOAM-NearReadPatch-Mesh1" />
<write-data name="UWind" mesh="OpenFOAM-NearReadPatch-Mesh1" />
<mapping:nearest-neighbor direction="read" from="OpenFOAM-Relaxation-Mesh1" constraint="consistent" />
<mapping:nearest-neighbor direction="write" to="OpenFOAM-NearReadPatch-Mesh1" constraint="conservative" />
</participant>
<participant name="OpenFOAM1">
<!-- near<->HOS -->
<provide-mesh name="OpenFOAM-Relaxation-Mesh1" />
<provide-mesh name="OpenFOAM-Coupling-Mesh1" />
<provide-mesh name="OpenFOAM-NearReadPatch-Mesh1" />
<receive-mesh name="HOS-Relaxation-Mesh1" from="HOS-Coupling" />
<read-data name="etaHOS" mesh="OpenFOAM-Relaxation-Mesh1" />
<read-data name="UHOS" mesh="OpenFOAM-Relaxation-Mesh1" />
<write-data name="etaVOF" mesh="OpenFOAM-Coupling-Mesh1" />
<write-data name="etaShifted" mesh="OpenFOAM-Coupling-Mesh1" />
<write-data name="wVOF" mesh="OpenFOAM-Coupling-Mesh1" />
<write-data name="weights" mesh="OpenFOAM-Coupling-Mesh1" />
<mapping:linear-cell-interpolation direction="read" from="HOS-Relaxation-Mesh1" to="OpenFOAM-Relaxation-Mesh1" constraint="consistent" />
<!-- near<->wind -->
<write-data name="p_rgh" mesh="OpenFOAM-Relaxation-Mesh1" />
<write-data name="UNear" mesh="OpenFOAM-Relaxation-Mesh1" />
<read-data name="p_rgh" mesh="OpenFOAM-NearReadPatch-Mesh1" />
<read-data name="UWind" mesh="OpenFOAM-NearReadPatch-Mesh1" />
</participant>
<participant name="HOS-Coupling">
<!-- HOS<->wind -->
<provide-mesh name="HOS-Wind-Mesh1" />
<receive-mesh name="Wind-Coupling-Mesh1" from="OpenFOAM-Wind1" />
<read-data name="pWind" mesh="HOS-Wind-Mesh1" />
<write-data name="etaHOS" mesh="HOS-Wind-Mesh1" />
<mapping:linear-cell-interpolation direction="read" from="Wind-Coupling-Mesh1" to="HOS-Wind-Mesh1" constraint="consistent" />
<!-- HOS<->near -->
<provide-mesh name="HOS-Relaxation-Mesh1" />
<provide-mesh name="HOS-Coupling-Mesh1" />
<receive-mesh name="OpenFOAM-Coupling-Mesh1" from="OpenFOAM1" />
<read-data name="etaVOF" mesh="HOS-Coupling-Mesh1" />
<read-data name="etaShifted" mesh="HOS-Coupling-Mesh1" />
<read-data name="wVOF" mesh="HOS-Coupling-Mesh1" />
<read-data name="weights" mesh="HOS-Coupling-Mesh1" />
<write-data name="etaHOS" mesh="HOS-Relaxation-Mesh1" />
<write-data name="UHOS" mesh="HOS-Relaxation-Mesh1" />
<mapping:nearest-neighbor direction="read" from="OpenFOAM-Coupling-Mesh1" to="HOS-Coupling-Mesh1" constraint="consistent" />
</participant>
<!-- wind<->HOS -->
<m2n:sockets acceptor="OpenFOAM-Wind1" connector="HOS-Coupling" exchange-directory=".." />
<time-window-size value="0.025" />
<max-time value="400.0" />
<participants first="OpenFOAM-Wind1" second="HOS-Coupling" />
<exchange data="etaHOS" mesh="HOS-Wind-Mesh1" from="HOS-Coupling" to="OpenFOAM-Wind1" initialize="0" />
<exchange data="pWind" mesh="Wind-Coupling-Mesh1" from="OpenFOAM-Wind1" to="HOS-Coupling" initialize="0" />
<m2n:sockets acceptor="OpenFOAM-Wind1" connector="OpenFOAM1" exchange-directory=".." />
<participants first="OpenFOAM-Wind1" second="OpenFOAM1" />
<!-- DMA-write -->
<exchange data="p_rgh" mesh="OpenFOAM-NearReadPatch-Mesh1" from="OpenFOAM-Wind1" to="OpenFOAM1" initialize="0" />
<exchange data="UWind" mesh="OpenFOAM-NearReadPatch-Mesh1" from="OpenFOAM-Wind1" to="OpenFOAM1" initialize="0" />
<!-- JIT-read -->
<exchange data="p_rgh" mesh="OpenFOAM-Relaxation-Mesh1" from="OpenFOAM1" to="OpenFOAM-Wind1" initialize="0" />
<exchange data="UNear" mesh="OpenFOAM-Relaxation-Mesh1" from="OpenFOAM1" to="OpenFOAM-Wind1" initialize="0" />
<!-- near<->HOS -->
<m2n:sockets acceptor="OpenFOAM1" connector="HOS-Coupling" exchange-directory=".." />
<participants first="OpenFOAM1" second="HOS-Coupling" />
<exchange data="etaHOS" mesh="HOS-Relaxation-Mesh1" from="HOS-Coupling" to="OpenFOAM1" initialize="0" />
<exchange data="UHOS" mesh="HOS-Relaxation-Mesh1" from="HOS-Coupling" to="OpenFOAM1" initialize="0" />
<exchange data="etaVOF" mesh="OpenFOAM-Coupling-Mesh1" from="OpenFOAM1" to="HOS-Coupling" initialize="0" />
<exchange data="etaShifted" mesh="OpenFOAM-Coupling-Mesh1" from="OpenFOAM1" to="HOS-Coupling" initialize="0" />
<exchange data="wVOF" mesh="OpenFOAM-Coupling-Mesh1" from="OpenFOAM1" to="HOS-Coupling" initialize="0" />
<exchange data="weights" mesh="OpenFOAM-Coupling-Mesh1" from="OpenFOAM1" to="HOS-Coupling" initialize="0" />
</precice-configuration>
