On suggestion of @uekerman I am opening an issue.
I was trying to run the a 2-way FSI simulation (OpenFOAM +CalculiX, the OF adapter is a bit modified for interFoam).
As for preCICE I use v2,1 and CalculiX adapter with CCXv2.16.
This the precice config that I am using.
precice-config.xml (3.2 KB)
I get the following in CalculiX side:
Setting up preCICE participant Calculix, using config file: config.yml
---[precice] This is preCICE version 2.1.0
---[precice] Revision info: v2.1.0-2-g42abc38c-dirty
---[precice] Configuring preCICE with configuration "./precice-config.xml"
---[precice] I am participant "Calculix"
Set ID Found
Read data 'Forces0' found with ID # '2'.
Write data 'Displacements0' found with ID # '3'.
---[precice] Setting up master communication to coupling partner/s
---[precice] Masters are connected
---[precice] Setting up preliminary slaves communication to coupling partner/s
---[precice] Prepare partition for mesh Solid
---[precice] Gather mesh Solid
---[precice] Send global mesh Solid
---[precice] Setting up slaves communication to coupling partner/s
---[precice] Slaves are connected
ASSERTION FAILED
Location: void precice::acceleration::Acceleration::checkDataIDs(const DataMap&) const
File: /home/prasad/Downloads/precice/src/acceleration/Acceleration.cpp:12
Rank: 0
Failed expression: valid
Argument 0: Data with ID 2 unknown.
P.S: Not really sure what to name the topic, so please feel free to improve it or make suggestions.
