I’m getting an error “ASSERTION FAILED”, when trying to couple two opposing perpendicular flaps. I’m using Calculix, OF, precice3. The error occurs on both the solid components.
I have attached a copy of the error log and the precice-config.xml
Before investigating potential causes, could you please upgrade to the latest preCICE (v3.1.2) and try again? This assertion is related to the time samples, and a lot of the related code has been updated between v3.0.0 and the latest version.
I did manage to fix my issue without updating preCICE (but have updated anyway).
The issue lied in my precice-config.xml file where I hadn’t mapped all the participant correctly. Correcting this allowed my simulation to run to completion.
