I am developing an adapter using preCICE for the Giraffe solver which is an FEM that uses beam elements, similar to the MBDyn, to do FSI couple with OpenFOAM. I ran the single perpendicular flap and the Turek benchmark without problems using both explicity and implicity couplings.
But when I tried to run the multiple perpendicular flap case, I am facing an error with description of ASSERTION FAILED, similar to what was reported in this Topic of the preCICE forum: preCICE/Official adapters and tutorials: ASSERTION FAILED usedDegree >= 1. This error hapens when my adapter requires the preCICE forces calculated by OpenFOAM, in the very first iteration:
// read forces from preCICE
std::cout << "[Giraffe-adapter] Reading forces from preCICE" << std::endl;
participant->readData(meshName, readDataName, nodesIDs, dt , preCICE_Forces);
Leading to this error:
ASSERTION FAILED
Location: Eigen::VectorXd precice::time::Storage::sample(double) const
File: /home/rodolfo/programas/precice-3.1.2/src/time/Storage.cpp:199
Expression: usedDegree >= 1
Rank: 0
Arguments: none
This happens in both terminals executing the solid part.
I would like any help, because I don’t know if is a problem in my adapter that is not yet prepared for multiple coupling or a configuration or code problem of preCICE.
Thanks,
Rodolfo Curci Puraca
precice-config.xml (4.7 KB)
Solid_1_error_log.txt (4.3 KB)
Solid_2_error_log.txt (4.3 KB)
