—[precice] ERROR: RBF linear system has not converged. Try to fix axis-aligned mapping setups by marking perpendicular axis as dead.
I get this error when I run the perpendicular flap tutorial for Openfoam- deal.ii. Has anyone encountered the same problem or have any suggestion to what might be the fix for the error ?
Hi @abimathi
I guess you run the 3D examples. In this case, yes, I can reproduce it. However, if you run the 2D example (flap_perp_2D, which requires to build the dealii program in 2D), it should work.
