I want to learn the underlying principles of coupling in PreCICE. Where should I start?
Hi @Carl,
The best ways to get started is the Quickstart guide or the high-intensity course at the preCICE workshop.
Best
Frédéric
Thank you
But I also want to learn the underlying logic of code structure. As a junior developer, what should I do?
Have a look at the Quickstart to get a feel on how preCICE is supposed to be used and then have a look at the tutorials. If you want to get hands-on, then the elastic-tube-1d tutorial is a good start as they are implemented without external solvers directly using the preCICE API.
Tinker, learn, understand, enjoy. ![]()
