Now I want to install preCICE on my cluster. My cluster is working on the RedHatEnterpriseServer with Red Hat Enterprise Linux Server release 6.8.
I am using preCISE-2.5
I hope I could receive some answers!
Thank You so much.
Thank You so much.
Hi there,
RHEL 6.8 is quite an old version which doesn’t provide packages with recent enough versions of required dependencies.
You would have to build the dependencies as well as preCICE, bindings and needed adapters from source.
Given the scale of that, I would recommend having a look at spack.
Hi fsimonis!
Thank you for your reply. I will try to with other operation systems.
Hoai Thanh
