Heat-Exchange Tutorial in PreCICE
Hi, I’m having a problem running the heat-Exchange tutorial. The boundary condition given in the official tutorial is Robin-Robin because it is more stable. However, I wanted to try the fluid-Neumann and solid-Dirichlet boundaries. When I’m done setting it up, I run buoyantSimpleFoam in OpenFoam and this error happens.
Since less data is exchanged, I only define Temperature and Heat-Flux to be exchanged. But the precice-config.xml error left me confused, and I couldn’t figure out what was wrong with the definition. data: scalar means where have problems with the definition of the data being exchanged? Thank you!
When you want to define which data a mesh is using you should use the
<use-data name="{string}"/>
tag. Currently you are using
<data:scalar name="{string}"/>
which should not be used within the <mesh> tags. You can find more information about this in the XML reference about defining data on meshes.
Thank you for your advice! It was my carelessness that led to the problem.
No worries. I am glad it was so easy to fix. :slight_smile:
Hello, the above problem has been solved. But here comes a new problem. I have checked several times, but I still don’t know the source of the problem. Can you help me see what’s wrong with it?
For the heat-exchangr tutorials, I want to exchange Temperature and heat-flux on the two interfaces (Inner-interface and Outer-interface). The solid domain transmits heat-flux to the inner and outer fluid domains, and the inner and outer fluid domains transmit Temperature to the solid domain.
The problem is shown below. And config.yml and precice-config.xml files are also shown.
@tianhk please open a new topic for the new problem so that we have a clear segregation of the discussion.
