Coupling openfoam of rhoPimpleFoam with calculix
Hi everyone, I am new to precice , and I what to use the precice to do FSI. My coupling situation is flow pass by naca0012 using rhoPimpleFoam for fluid ,and solid using calculix.
Here is the error from rhopimplefoam:
--> FOAM FATAL ERROR: (openfoam-2212 patch=230612)
Different dimensions for '(a = b)'
     dimensions : [1 -1 -2 0 0 0 0] != [0 2 -2 0 0 0 0]
the unit of [1 -1 -2 0 0 0 0] is the real pressure, and [0 2 -2 0 0 0 0] is the Kinematic pressure.
according to the FSI tutorial, in the incompressible fluid, openfoam using Kinematic pressure, but in the compressible fluid, openfoam using real pressure. so it may be the cause of the error. My question are how to fix this error when coupling compressible fluid with solid. What are the different of precice-adapter calculate the force and stress for compressible fluid and incompressible fluid.
Could anyone help me?
Best
Chen
Even I change the solver to sonicDyMFoam, same error still occur. I don’t know why there is different dimensions from which quanlity, pressure? stress ? force?
@hkchm this sounds like a bug in the adapter. Could you please upload a test case to reproduce the error (ideally as simple as possible)?
Feel free to directly open an issue in the adapter, if you prefer:
Hi, I am also getting the same error.
---[precice] e[0m Compute "read" mapping from mesh "Solid-Mesh" to mesh "Fluid-Mesh".
---[precice] e[0m iteration: 2 of 100, time-window: 1, time: 0 of 2.5, time-window-size: 0.0001, max-timestep-length: 0.0001, ongoing: yes, time-window-complete: no, read-iteration-checkpoint
[0]
[0]
[0] --> FOAM FATAL ERROR: (openfoam-2106 patch=211215)
[0] Different dimensions for '(a = b)'
[0]
Any update on the issue?
Edit: I tried several suggested solutions, including:
  • using
    nameP p_rgh;
    in preciceDict
  • Using a turbulence model other than kOmegaSST (I tried laminar and SpalartAllmaras)
But the error persists.
OpenFOAM: v2106
System: Ubuntu 18.04
preCICE version: 2.3.0
OpenFOAM adapter version: v1.2.3
Here is my case file if needed. Please feel free to ask for details if necessary…
fluid-openfoam.zip (19.0 KB)
Hello everyone, I don’t know if you’ve solved this problem, which I’ve also encountered. I might be suggesting something you’ve surely already tried, but have you tried removing or commenting out the OpenFOAM functionObjects from the controlDict? In my case, for example, it was the wallShearStress function that was causing this problem. After downloading your hconel zip file, I saw that you also have the wallShearStress function inside wallShearStressField. If you haven’t tried it yet, I recommend temporarily removing the functions from the controlDict, and it should work.
I still need to look into this issue more thoroughly, but it’s a start—maybe using these functions as post-processing could work.
System: Rocky Linux 9.7 (Blue Onyx)
OpenFOAM: v2406
preCICE:3.3.1
