I am performing an FSI simulation of an impeller used for ventilation. As I am not achieving the best agreement with experimental data with a normal flow simulation (simpleFoam with MRF), I am trying this.
The coupling is between pimpleFoam (with MRF and not sliding mesh) and solidDisplacementFoam, both solvers of OpenFoam. Despite they are transient solvers, I am only interested in the steady state case so they are run like steady solvers.
The case has been configured using the tutorial “perpendicular flap” with some changes I saw mainly from your website: Configuration overview | preCICE - The Coupling Library and The OpenFOAM adapter | preCICE - The Coupling Library. I am using an explicit serial coupling as the deformations should be tiny (thus the flow slighlty modified). I prefer to solve it in serial until the flow and the deformations are steady. You can find attached the preCICE configuration and both dictionaries (fluid and solid). I am using a local machine.
To run the fluid case I use: mpirun -np 8 pimpleFoam -parallel
To run the solid case I use: mpirun -np 4 solidDisplacementFoam -parallel
Sorry but preCICE is not outputting any log file, so I am going to attach the foamLog for each solver. Basically, the communication is not successful between solvers, as the structural solver is not iterating and outputting for every iteration the following:
GAMG: Solving for Dx, Initial residual = 0, Final residual = 0, No Iterations 0
GAMG: Solving for Dy, Initial residual = 0, Final residual = 0, No Iterations 0
GAMG: Solving for Dz, Initial residual = 0, Final residual = 0, No Iterations 0
ExecutionTime = 2.64 s ClockTime = 113 s
The fluid solution is initialized from an already converged solution, so the forces are there and should be sent to the structural solver.
If anyone could give me a hand I would very much appreciate it!
Thanks a lot,
Marc
precice-config.xml (1.6 KB)
logFluid.txt (13.3 KB)
logSolid.txt (3.5 KB)
preciceDict(fluid).txt (639 Bytes)
preciceDict(solid).txt (968 Bytes)
