wmkdepend: could not open 'precice/SolverInterface.hpp' for source file 'Adapter.C': No such file or directory
wmkdepend: could not open 'precice/SolverInterface.hpp' for source file 'preciceAdapterFunctionObject.C': No such file or directory
wmkdepend: could not open 'precice/SolverInterface.hpp' for source file 'FF/FF.C': No such file or directory
wmkdepend: could not open 'precice/SolverInterface.hpp' for source file 'FSI/FSI.C': No such file or directory
wmkdepend: could not open 'precice/SolverInterface.hpp' for source file 'CHT/CHT.C': No such file or directory
wmkdepend: could not open 'precice/SolverInterface.hpp' for source file 'Interface.C': No such file or directory
Allwmake.log wmake.log attached.
Thank you!
Thank you for being part of the preCICE community!
g++ -std=c++11 -m64 -pthread -DOPENFOAM=2206 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I/home/user/OpenFOAM/OpenFOAM-v2206/src/finiteVolume/lnInclude -I/home/user/OpenFOAM/OpenFOAM-v2206/src/meshTools/lnInclude -I/home/user/OpenFOAM/OpenFOAM-v2206/src/transportModels/ -I/home/user/OpenFOAM/OpenFOAM-v2206/src/transportModels/incompressible/lnInclude -I/home/user/OpenFOAM/OpenFOAM-v2206/src/transportModels/compressible/lnInclude -I/home/user/OpenFOAM/OpenFOAM-v2206/src/transportModels/twoPhaseMixture/lnInclude -I/home/user/OpenFOAM/OpenFOAM-v2206/src/transportModels/interfaceProperties/lnInclude -I/home/user/OpenFOAM/OpenFOAM-v2206/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/home/user/OpenFOAM/OpenFOAM-v2206/src/thermophysicalModels/basic/lnInclude -I/home/user/OpenFOAM/OpenFOAM-v2206/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/user/OpenFOAM/OpenFOAM-v2206/src/TurbulenceModels/compressible/lnInclude -I/home/user/OpenFOAM/OpenFOAM-v2206/src/TurbulenceModels/incompressible/lnInclude -I/home/user/OpenFOAM/OpenFOAM-v2206/src/triSurface/lnInclude -I../ -iquote. -IlnInclude -I/home/user/OpenFOAM/OpenFOAM-v2206/src/OpenFOAM/lnInclude -I/home/user/OpenFOAM/OpenFOAM-v2206/src/OSspecific/POSIX/lnInclude -fPIC -c preciceAdapterFunctionObject.C -o Make/linux64Gcc940DPInt32Opt/preciceAdapterFunctionObject.o
FSI/Force.C: In constructor ‘preciceAdapter::FSI::Force::Force(const Foam::fvMesh&, std::string, std::string)’:
FSI/Force.C:22:29: error: ‘make_unique’ is not a member of ‘std’
22 | ForceOwning_ = std::make_unique<volVectorField>(volVectorField(
FSI/Force.C:22:29: note: ‘std::make_unique’ is only available from C++14 onwards
FSI/Force.C:22:55: error: expected primary-expression before ‘>’ token
which I already experienced with some older OpenFOAM versions. I assume that in this case it must be an old compiler or a similar issue. Could you please run g++ --version and report the version?
Can you please try changing:
In FSI/Force.H, change the ForceOwning_ declaration to Foam::autoPtr<Foam::volVectorField> ForceOwning_;
In FSI/Force.C, change line 22 to ForceOwning_ = new volVectorField(
Yes, in fact I tried both. I just tried again. The error msg:
FSI/Force.C: In constructor ‘preciceAdapter::FSI::Force::Force(const Foam::fvMesh&, std::string, std::string)’: FSI/Force.C:34:36: error: use of deleted function ‘void Foam::autoPtr::operator=(T*) [with T = Foam::GeometricField<Foam::Vector, Foam::fvPatchField, Foam::volMesh>]’ 34 | Foam::vector::zero))); | ^ In file included from /home/user/OpenFOAM/OpenFOAM-v2206/src/OpenFOAM/lnInclude/runTimeSelectionTables.H:46, from /home/user/OpenFOAM/OpenFOAM-v2206/src/OpenFOAM/lnInclude/token.H:52, from /home/user/OpenFOAM/OpenFOAM-v2206/src/OpenFOAM/lnInclude/Istream.H:50, from /home/user/OpenFOAM/OpenFOAM-v2206/src/OpenFOAM/lnInclude/ISstream.H:42, from /home/user/OpenFOAM/OpenFOAM-v2206/src/OpenFOAM/lnInclude/IOstreams.H:41, from ./Utilities.H:40, from ./CouplingDataUser.H:4, from FSI/ForceBase.H:5, from FSI/Force.H:4, from FSI/Force.C:1: /home/user/OpenFOAM/OpenFOAM-v2206/src/OpenFOAM/lnInclude/autoPtr.H:253:14: note: declared here 253 | void operator=(T* p) = delete; | ^~~~~~~~ make: *** [/home/user/OpenFOAM/OpenFOAM-v2206/wmake/rules/General/transform:34: Make/linux64Gcc940DPInt32Opt/FSI/Force.o] Error 1
The previous email has the log files attached.
I’m using my own compiled OF. Other than, it’s all quite standard.
