Bug/wrong setting when output data with FREQUENCY
Hi there,
I’m using openfoam-calculix adapters to simulate FSI problems. When I output data in calculix without appointing output frequency, everything goes fine, for example:
*NODE PRINT, NSET=probe
U
However, to avoid the data file being too large, I use frequency card, like;
*NODE PRINT, NSET=probe, FREQUENCY=1000
U
After this, the simulation diverse after running for a long time (about 1-2 hours). Is this a bug? How can I fix this?
Hi, I also use the FREQUENCY card, and I never encountered issues like the one you describe. It’s quite puzzling since generally the NODE PRINT output does not influence the calculation, right?
Sorry I can’t be of more help. Hope you find the source of the problem soon. :slight_smile:
this is strange as the results output of CalculiX is independent of the adapter. Does this occur with other values of the FREQUENCY tag? Such as FREQUENCY= 10, 100 etc.?
Yes, it still breaks whatever frequency is given.
