Similarly, if I start the precice-openfoam-calculix coupling by fixing all degrees of freedom of all nodes in calculix, the result is also correct.
*BOUNDARY
Nall, 1,1
*BOUNDARY
*Nall, 2,3
However, if the x and z degrees of freedom of all nodes are fixed and all nodes are given a displacement function,.
*BOUNDARY
Nall, 1,1
*BOUNDARY,AMPLITUDE=MyAmplitude
*Nall, 2, 2 ,1
*BOUNDARY
Nall, 3
The openfoam terminal will output an error
zone:0 nCells:12288 voxels:(156 156 1) bb:(-1.47245e-06 -1.47245e-06 -1.47245e-06) (1 0.410001 1)
zone:1 nCells:12120 voxels:(156 156 1) bb:(0.149999 0.119999 -1.17712e-06) (0.750001 0.280001 1)
Overset analysis : nCells : 24408
calculated : 23516
interpolated : 616 (interpolated from local:616 mixed local/remote:0 remote:0)
hole : 276
forces Forces write:
Sum of forces
Total : (1.28018 0 0)
Pressure : (0 0 0)
Viscous : (1.28018 0 0)
Sum of moments
Total : (0 0.64009 -0.256036)
Pressure : (0 0 0)
Viscous : (0 0.64009 -0.256036)
Courant Number mean: 0.163625 max: 0.823893
Time = 0.0005
DICPCG: Solving for cellDisplacementx, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG: Solving for cellDisplacementy, Initial residual = 1, Final residual = 2.00145e-16, No Iterations 1
[0]PETSC ERROR: Caught signal number 8 FPE: Floating Point Exception,probably divide by zero
This is the log file of OF and ccx
ccx log.txt (7.1 KB)
OFlog.txt (10.5 KB)
However, as can be seen from the output of the first iteration step of precice, the initial state is correct, the forces and displacements of the first iteration step of the solid and fluid appear to be correct.
Fluid-Mesh-Fluid.init.txt (12.2 KB)
Fluid-Mesh-Fluid.it1.txt (18.1 KB)
Solid-Mesh-Fluid.init.txt (16.3 KB)
Solid-Mesh-Fluid.it1.txt (22.5 KB)
</DataArray>
</Cells>
<PointData Scalars="Rank " Vectors="Displacement Force ">
<DataArray type="UInt32" Name="Rank" NumberOfComponents="1" format="ascii">
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
</DataArray>
<DataArray type="Float64" Name="Displacement" NumberOfComponents="3" format="ascii">
6.92202e-311 4.6801e-311 4.6801e-311 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0 0 1.25e-05 0
</DataArray>
<DataArray type="Float64" Name="Force" NumberOfComponents="3" format="ascii">
**17.7465 -0.00329648 0 19.7678 -0.171797 0 17.7465 0.00744945 0 19.7678 0.303624 0 23.3511 -0.518046 0 21.8297 -0.239513 0 21.8297 0.270005 0 23.3512 0.6537 0 -11.4843 -0.0298418 0 -0.928967 -0.0332703 0 -2.06451 -0.0364896 0 -1.84385 -0.0376827 0 -1.8342 -0.0384044 0 -1.80401 -0.0388428 0 -1.78361 -0.039142 0 -1.77047 -0.0393555 0 -1.76014 -0.0395108 0 -1.75305 -0.0396259 0 -1.74754 -0.0397122 0 -1.74342 -0.0397774 0 -1.74022 -0.0398273 0 -1.73761 -0.039866 0 -1.73556 -0.0398967 0 -1.73391 -0.0399215 0 -1.73249 -0.0399423 0 -1.73128 -0.0399604 0 -1.73028 -0.039977 0 -1.72943 -0.039993 0 -1.72862 -0.0400092 0 -1.72786 -0.040026 0 -1.72718 -0.0400439 0 -1.72654 -0.0400633 0 -1.7259 -0.0400845 0 -1.72525 -0.0401077 0 -1.72461 -0.040133 0 -1.72396 -0.0401607 0 -1.72328 -0.0401907 0 -1.72257 -0.040223 0 -1.72186 -0.0402577 0 -1.72112 -0.0402946 0 -1.72033 -0.0403338 0 -1.71948 -0.0403751 0 -1.7186 -0.0404183 0 -1.71771 -0.0404633 0 -1.71679 -0.0405097 0 -1.7158 -0.0405575 0 -1.71476 -0.0406062 0 -1.71369 -0.0406555 0 -1.7126 -0.040705 0 -1.71147 -0.0407544 0 -1.71029 -0.0408031 0 -1.70909 -0.0408505 0 -1.70787 -0.040896 0 -1.70662 -0.0409391 0 -1.70533 -0.0409789 0 -1.70405 -0.0410145 0 -1.70282 -0.0410447 0 -1.70158 -0.0410685 0 -1.70032 -0.0410847 0 -1.69914 -0.0410918 0 -1.6981 -0.0410876 0 -1.69718 -0.04107 0 -1.69638 -0.0410368 0 -1.69585 -0.0409849 0 -1.69574 -0.0409106 0 -1.69604 -0.0408092 0 -1.69705 -0.0406753 0 -1.69918 -0.0405024 0 -1.70259 -0.0402807 0 -1.70891 -0.0400021 0 -1.71751 -0.0396498 0 -1.733 -0.0392069 0 -1.75773 -0.0387084 0 -1.75946 -0.0377294 0 -1.9901 -0.0391126 0 -0.760942 -0.0238 0 -12.0926 -0.128279 0 -11.2134 -0.175088 0 -0.106436 0.00472572 0 -11.2134 0.130692 0 -12.0926 0.0672072 0 -0.76094 0.0261074 0 -1.99009 0.0342058 0 -1.75946 0.0339511 0 -1.75772 0.0346795 0 -1.733 0.035106 0 -1.7175 0.0354415 0 -1.70891 0.0356853 0 -1.70258 0.0358569 0 -1.69918 0.0359736 0 -1.69705 0.0360459 0 -1.69604 0.0360829 0 -1.69573 0.0360913 0 -1.69585 0.0360764 0 -1.69638 0.0360424 0 -1.69718 0.0359924 0 -1.6981 0.0359292 0 -1.69914 0.035855 0 -1.70032 0.0357717 0 -1.70157 0.0356808 0 -1.70281 0.0355838 0 -1.70405 0.0354818 0 -1.70532 0.0353757 0 -1.70661 0.0352664 0 -1.70786 0.0351547 0 -1.70908 0.0350414 0 -1.71029 0.034927 0 -1.71147 0.034812 0 -1.7126 0.0346969 0 -1.71369 0.0345821 0 -1.71476 0.0344681 0 -1.7158 0.0343551 0 -1.71678 0.0342434 0 -1.71771 0.0341333 0 -1.7186 0.0340251 0 -1.71948 0.0339188 0 -1.72033 0.0338146 0 -1.72112 0.0337126 0 -1.72186 0.0336129 0 -1.72257 0.0335155 0 -1.72328 0.0334205 0 -1.72396 0.0333276 0 -1.72461 0.0332368 0 -1.72525 0.033148 0 -1.7259 0.0330609 0 -1.72654 0.0329751 0 -1.72717 0.0328904 0 -1.72786 0.0328062 0 -1.72862 0.0327218 0 -1.72942 0.0326366 0 -1.73028 0.0325496 0 -1.73128 0.0324598 0 -1.73249 0.0323658 0 -1.7339 0.0322657 0 -1.73555 0.0321572 0 -1.7376 0.0320379 0 -1.74021 0.0319044 0 -1.74342 0.0317519 0 -1.74754 0.0315742 0 -1.75304 0.0313628 0 -1.76014 0.0311069 0 -1.77047 0.0307897 0 -1.7836 0.0303858 0 -1.80401 0.0298584 0 -1.8342 0.0291377 0 -1.84384 0.0281332 0 -2.06451 0.0264226 0 -0.928965 0.0245707 0 -11.4843 0.00559322 0 -11.0787 -0.02138 0 -0.430781 -0.00580164 0 -11.0787 -0.0163064 0 -8.58403 -0.0969777 0 2.57148 -0.171521 0 1.35101 -0.160022 0 1.58456 -0.161766 0 1.59162 -0.161222 0 1.62084 -0.16098 0 1.64046 -0.16077 0 1.65291 -0.160626 0 1.66284 -0.160534 0 1.66966 -0.160477 0 1.675 -0.160448 0 1.67903 -0.160436 0 1.68217 -0.160436 0 1.68469 -0.160442 0 1.68661 -0.160451 0 1.68808 -0.16046 0 1.68925 -0.160466 0 1.69012 -0.160467 0 1.69068 -0.160461 0 1.69099 -0.160448 0 1.69113 -0.160425 0 1.69112 -0.160392 0 1.69089 -0.160348 0 1.69049 -0.160293 0 1.68996 -0.160226 0 1.68931 -0.160146 0 1.68851 -0.160054 0 1.68757 -0.159948 0 1.68653 -0.15983 0 1.68536 -0.159698 0 1.68406 -0.159553 0 1.68263 -0.159394 0 1.6811 -0.159221 0 1.67948 -0.159035 0 1.67773 -0.158836 0 1.67585 -0.158624 0 1.67384 -0.158398 0 1.67172 -0.15816 0 1.6695 -0.157908 0 1.66715 -0.157645 0 1.66465 -0.157369 0 1.66201 -0.157081 0 1.65925 -0.156781 0 1.65633 -0.156471 0 1.65324 -0.156149 0 1.64999 -0.155818 0 1.64658 -0.155476 0 1.64295 -0.155126 0 1.63906 -0.154767 0 1.63495 -0.1544 0 1.63062 -0.154027 0 1.62596 -0.153648 0 1.6209 -0.153264 0 1.61543 -0.152877 0 1.60953 -0.152489 0 1.60302 -0.152102 0 1.59574 -0.151719 0 1.58763 -0.151342 0 1.57836 -0.150978 0 1.56746 -0.150631 0 1.55471 -0.15031 0 1.53841 -0.150026 0 1.51905 -0.149797 0 1.49209 -0.149643 0 1.45512 -0.149595 0 1.43971 -0.149669 0 1.20441 -0.149845 0 2.37638 -0.15051 0 -8.60668 -0.167357 0 -8.12096 -0.0164045 0 2.79548 -0.000318558 0 -8.12096 -0.0104092 0 -8.60667 0.137032 0 2.37639 0.153114 0 1.20442 0.149828 0 1.43972 0.150531 0 1.45513 0.150771 0 1.4921 0.151191 0 1.51907 0.151666 0 1.53842 0.152179 0 1.55472 0.152717 0 1.56747 0.153267 0 1.57837 0.153825 0 1.58764 0.154385 0 1.59575 0.154945 0 1.60304 0.155503 0 1.60954 0.156057 0 1.61545 0.156605 0 1.62091 0.157146 0 1.62598 0.157679 0 1.63063 0.158204 0 1.63497 0.15872 0 1.63907 0.159226 0 1.64296 0.159722 0 1.64659 0.160207 0 1.65 0.160682 0 1.65325 0.161145 0 1.65634 0.161596 0 1.65926 0.162035 0 1.66202 0.162462 0 1.66466 0.162876 0 1.66716 0.163277 0 1.66951 0.163666 0 1.67173 0.164041 0 1.67385 0.164402 0 1.67586 0.16475 0 1.67775 0.165085 0 1.67949 0.165405 0 1.68112 0.165712 0 1.68264 0.166005 0 1.68407 0.166284 0 1.68537 0.166549 0 1.68654 0.166801 0 1.68758 0.167038 0 1.68852 0.167263 0 1.68932 0.167475 0 1.68998 0.167674 0 1.6905 0.16786 0 1.6909 0.168035 0 1.69113 0.168199 0 1.69115 0.168353 0 1.691 0.168498 0 1.69069 0.168634 0 1.69013 0.168763 0 1.68926 0.168888 0 1.6881 0.169009 0 1.68662 0.16913 0 1.6847 0.169253 0 1.68218 0.169382 0 1.67905 0.169522 0 1.67501 0.169678 0 1.66967 0.169856 0 1.66285 0.170067 0 1.65292 0.170316 0 1.64048 0.170619 0 1.62085 0.170984 0 1.59163 0.171341 0 1.58457 0.172122 0 1.35102 0.169531 0 2.57149 0.187159 0 -8.58402 0.0652325 0 -8.19054 -0.197719 0 3.14395 0.0112459 0 -8.19054 0.164001 0**
</DataArray>
</PointData>
</Piece>
</UnstructuredGrid>
</VTKFile>
I combine the efforts of the first iteration of the fluid and the solid, and I find that the resultant force of the first iteration of the fluid in the X and Y directions is equal to the resultant force of the first iteration of the fluid in the X and Y directions, respectively.
It appears that the result of precice openfoam calculix in the first iteration step is correct, and the problem may arise when the fluid-structure coupling interface uses displacement to move the fluid mesh.
Time = 0.0005
