Hi
I’m trying to run the “Turek-Hron” tutorial provided with preCICE. I’ve followed the introduction page to the tutorial, but when I try to run it, dealii just doesn’t converge in the first time step. I’ve run the fluid case seperately and the inlet seems to work as intended. I close the following from dealii:
Timestep 1 @ 0.001s
_______________________________________________________________________________________
SOLVER STEP | LIN_IT LIN_RES RES_NORM RES_ABS U_NORM U_ABS
0 CST ASM SLV | 1 0.000e+00 1.000e+00 2.029e-02 1.000e+00 2.595e-08
1 CST ASM SLV | 1 0.000e+00 3.142e-08 6.375e-10 2.442e-08 6.336e-16
2 CST ASM CONVERGED!
Relative errors:
Displacement: 2.442e-08
Residual: 6.237e-09
v / V_0: 7.020e-03 / 7.020e-03
---[precice] relative convergence measure: relative two-norm diff of data "Stress" = 7.53e-01, limit = 1.00e-04, normalization = 1.83e+01, conv = false
---[precice] relative convergence measure: relative two-norm diff of data "Displacement" = 3.38e-02, limit = 1.00e-04, normalization = 1.08e-08, conv = false
---[precice] Mapping "Stress" consistent from "Fluid-Mesh-Centers" (ID 0) to "Solid-Mesh" (ID 2) for dimension 0 with polynomial set to separate
---[precice] Mapping "Stress" consistent from "Fluid-Mesh-Centers" (ID 0) to "Solid-Mesh" (ID 2) for dimension 1 with polynomial set to separate
---[precice] iteration: 16 of 100, time-window: 1, time: 0 of 15, time-window-size: 0.001, max-timestep-length: 0.001, ongoing: yes, time-window-complete: no, read-iteration-checkpoint
Does anyone have an idea, what I’m doing wrong? I run the following versions:
Dealii 9.4.0
OpenFOAM 2206
preCICE 2.5.0
Ubuntu 20.04
