Surface coupling of fluid-fluid simulation
Sorry, I am using p_rgh, which is why I have it in my preciceDict. I am not directly using p.
Regarding the phase-related variables: this shouldn’t be an issue for interFoam based solvers though, right? They only solve for one velocity equation, right?
I tried running the case only with interFoam and the solvers do mostly what I expect, except for the fact that in the Fluid-2 domain at the outlet, the alpha values are a bit larger than 1. I assume the issues are somehow part of my setup then.
I assume that there are the values that preCICE gives, right? Not the values that Fluid1 originally computes.
@Fujikawas is currently working on an extension of the IQN to bound values, and this could be a nice use case of that feature.
Is there already a timeplan for the release?
There is no specific timeplan for this feature, but this is the respective PR for treating the overshooting issues: Add transformation in acceleration methods to treat bounded values by Fujikawas · Pull Request #1952 · precice/precice · GitHub
With nice use cases and feedback, any development can get faster! :smiling_face:
For you, right now, one alternative option would be using Aitken instead of IQN (with the usual performance disadvantages).
By the way:
Does this mean that you used the same setup, but a different solver? Do you think this is an issue with the solver, or that the adapter does not fully cover your solver?
Hi Makis, I tested the solver again the same case with coupling and without coupling and it seems like the solver does not do what I expected from the start. All coupled fields dont match with the non coupled case. Do you think this supports your idea that fields from a potential solver split do not get coupled properly? If it helps: I am using the openfoam-org-adapter with OpenFOAM-6
Hi @dennis,
sorry for delay, I overlooked your reply. Do you have any new information to add?
Partitioned flow simulations are definitely quite tricky, and I cannot give absolute answers on what works.
