sir, I am facing issues to couple the solid and fluid for multiphase simulation using precice. I had modified the tutorial case of flow over heated plate in precice and using laplacianFoam solver for solid and interCondensatingEvaporatingFoam for fluid. I had modified the 0 directory in fluid and also the transport properties in constant folder. But while running the case I am facing an error as mentioned below. please help me to solve this issue. Thanking You.
--> FOAM Warning :
bad lookup of turbulenceProperties (objectRegistry region0)
expected a compressibleTurbulenceModel, found a Stokes
--> FOAM Warning :
in file Utilities.C at line 17
Warning in the preCICE adapter:
The solver's timestep cannot be larger than the coupling timestep. Adjusting from 0.010000 to 0.000449
Starting time loop
Courant Number mean: 0.00375763 max: 0.0181192
Interface Courant Number mean: 0 max: 0
--> FOAM Warning :
The solver's timestep cannot be larger than the coupling timestep. Adjusting from 0.000539 to 0.000449
deltaT = 0.000448863
Time = 0.000448863
PIMPLE: iteration 1
smoothSolver: Solving for alpha.liquid, Initial residual = 1, Final residual = 0.961381, No Iterations 1000
Phase-1 volume fraction = 1 Min(alpha.liquid) = 1 Max(alpha.liquid) = 1
MULES: Correcting alpha.liquid
Liquid phase volume fraction = 1 Min(alpha.liquid) = 1 Max(alpha.liquid) = 1
smoothSolver: Solving for alpha.liquid, Initial residual = 0.372766, Final residual = 0.512178, No Iterations 1000
smoothSolver: Solving for T, Initial residual = 0.50319, Final residual = 0.384445, No Iterations 1000
min/max(T) = 300, 300
GAMG: Solving for p_rgh, Initial residual = 0.999987, Final residual = 0.00275921, No Iterations 10
GAMGPCG: Solving for p_rgh, Initial residual = 0.000191188, Final residual = 9.24922e-10, No Iterations 10
ExecutionTime = 1.02 s ClockTime = 2 s
--> FOAM FATAL ERROR: (openfoam-2212)
Error in the preCICE adapter:
There was a problem while configuring the adapter. See the log for details.
in file Utilities.C at line 32.
