Dear developers,
When my program is coupled with dealii, when one uses mpi and one doesn’t, it can be calculated without any problem. But when I use mpi at the same time, it hangs.
Also I tested multiple nodes also not able to pass data, it seems like they can’t find each other. Below is my config file and the file for the commit command.
precice-config.xml (2.8 KB)
new.txt (1.3 KB)
sub.txt (798 Bytes)
