Hello everyone,
I am a new user of preCICE, and I just installed it on top of a FEniCS docker image. I also installed python bindings which are ok since “import precice” works without any errors.
Unfortunately, when I try to test it using the provided solver-dummy and the 1D Elastic Tube cases, both scripts get stuck at the following row:
You could check the owner and file permissions in the container, e.g., with ls -la.
During initialization, one of the two solver writes a file in a precice-run/ directory, next to the configuration file (precice-config.xml). Is this directory created? It should contain some kind of address inside.
I installed from scratch everything on my workstation (before I was working on my laptop), following the same steps, and now it works. I have to go deeper into this, because I need to use the laptop too.
