one thing you could monitor is the Courant number. Another thing is the quality of the mesh.
Let me know how it goes.
myCase.zip (184.7 KB)
Hi
Can you take a look at this? I’ve started getting errors today that I wasn’t getting before. I haven’t changed anything, honestly. I have no idea what’s going on.
I didn’t get this error when I ran the same file yesterday.
Turan
At the moment, I don’t have FeniCs or Solids4foam installed. Can you try to prepare a case with CalculiX? Alternatively, Can you post the error messages?
Unfortunately, I don’t know CalculiX at all…
@Turan before coupling anything, I would first try to run a flow-only simulation and ensure that this is converging. It sounds like this is mostly a mesh and general simulation tuning issue, than a coupling issue.
I understand that the last post here was a while ago. Did you manage to make any progress in the meantime? If you already solved (partially) the issue, how did you achieve that?
