One step theta scheme in deal.ii adapter
Hello, I’m struggling to understand the mathematical background of the one-step theta scheme implemented in deal.ii adapter linear_elasticity.cc. In there the rhs is implemented as:
RHS=(M - theta * (1-theta) * delta_t^2*K) * V_n - delta_t * K * D_n + delta_t * theta * F_n+1 + delta_t * (1-theta) * F_n
I do not get the original time integration equation which leads to the above equation. I have a look in deal.ii step-23 tutorial which provides an explanation of the Rothe method, which also uses theta parameter and gives identical LHS:
https://www.dealii.org/current/doxygen/deal.II/step_23.html
Following that, the rhs should be:
RHS=M * (D_n+delta_t * V_n) - delta_t^2 * theta * (1-theta) * K * D_n + delta_t^2 * theta * (theta * F_n+1 + (1-theta)*F_n)
Any help to explain the differences would be appreciated.
Hi @vryy
have you already seen the related documentation on our website??
Thanks @DavidSCN. I overlooked it. That’s exactly what I’m looking for.
