Ok, so again in order to make this clear: Stress data = the formula above = vector valued data, which is not equal to Pressure data = scalar data, where the \tau_{ij} is not included. If you are still looking for an implementation of the above formula; the Stressdata field includes this already.
Regarding your original question: OpenFOAM calls the pressure field and data just p, which exists as you can see. However, the constructor of the Pressure field you want to add takes the name (again, p by default) as an argument
preciceAdapter::FSI::Pressure::Pressure(
const Foam::fvMesh& mesh,
const std::string nameP)
whereas you pass in the solver type
interface->addCouplingDataWriter(
dataName,
new Stress(mesh_, solverType_) /* TODO: Add any other arguments here */
Have a look at these lines for a similar example openfoam-adapter/FSI.C at 0c368d717bc5ec0fbd0aa4925c48a8164487fc3f · precice/openfoam-adapter · GitHub
