I’ve been using OpenFOAM for a few years and FSI have been attracted my attention all the time.
At the moment I would like to simulate the movement of a sphere inside a tube or channel, or even open flow (air). Initially the sphere is rigid, but eventually I would like to set some mechanical properties and study sphere deformation due to flow or contact with walls.
If you are aware of any tutorial I can do to start Id be very grateful for your help. I have some experience in FEA (ansys) but I have installed calculix and dealii as well and Im doing some tuts.
Already a word of advice about the sphere case you want to do: the current OpenFOAM adapter uses a moving mesh (interface capturing) approach. You will not be able to move the sphere tooo much.
