Dynamic coupling interface for OpenFOAM
Hello couplers, sorry for my long thread.
I am coupling a custom solver (thermalFoam) for heat conduction in frozen partially saturated soils with another solver (olaFlow) in order to model coastal permafrost erosion. olaFlow supplies the instantaneous water surface elevation at the water-permafrost boundary and thermalFoam use that data to apply the correct temperature boundary conditions. The coupling tool is preCICE. Now, the problem is that, even though the coupling works, the ablation process is not well resolved in that after the first occurrence of ablation at the coupling interface, cells are removed (deleted), and the newly exposed cells do not receive the thermal treatment that I expect them to get in order to advance the ablation process.
The sequence of events in my solver is summarized as follows :
At t=0, the preCICE OpenFOAM adapter reads the preciceDict. It finds the interface patches (waveFacing and erodedWall). It builds a communication mesh for preCICE based on the face centers of the waveFacing patch (but erodedWall is initially empty). preCICE then considers a static, fixed thermal-interface mesh.When olaFlow sends Alpha data. preCICE maps this data from ola-interface to its stored version of thermal-interface. The adapter correctly writes this data to the alphaWater field on the waveFacing patch.
When ablation occurs, my solver’s updateErosionBoundary.H script updates the topology of the water-permafrost interface. It removes a layer of cells. The polyTopoChange operation exposes new faces and assigns them to the erodedWall patch.
In the next time step, olaFlow again sends Alpha data. preCICE tries to map it to thermal-interface. However, preCICE is still using the mesh geometry from t=0. It has no knowledge of the new faces on the erodedWall patch. Consequently, no Alpha data is ever mapped or written to these new faces. The alphaWater field on the erodedWall patch faces remains at its initial value (zero). When my codedMixed boundary condition on erodedWall executes, it reads alphaWater, sees a value of 0, and concludes that the face is “dry” (wet = false). It then applies the low heat transfer coefficient for air (hwAir), stalling the ablation process and the erosion front from advancing.
Here is my olaFlow preciceDICT:
/*--------------------------------*- C++ -*----------------------------------*\
| \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \\    /   O peration     | Version:  v2506                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
|    \\/     M anipulation  |                                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      preciceDict;
preciceConfig "/home/omonifemi/pretest/precice_config.xml";
participant    olaFlow;
modules        (FF);
interfaces
  Interface1
    mesh        ola-interface;
    patches     (permafrostWall);
    locations   faceCenters;
    writeData ( Alpha );
    readData  ( );
FF
  solverType   incompressible;
  // OpenFOAM field that holds the phase fraction here:
  nameAlpha    alpha.water;    // <-- map 'Alpha' -> 'alpha.water'
  namePhi      phi;
  nameU        U;
  nameP        p_rgh;          // this are placeholders for future trials
Here is my thermalFoam preciceDict":
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      preciceDict;
participant    thermalFoam;
modules        (FF);
interfaces
  Interface1
    mesh        thermal-interface;
    patches     (waveFacing erodedWall);
    writeData ( );
    readData  ( Alpha );
FF
  //solver’s receiving field:
  nameAlpha    alphaWater;     // <-- map 'Alpha' -> 'alphaWater'
Here is 0/T boundary conditions:
|  \\    /   O peration     | Version:  2506                                  |
FoamFile
    version     2.0;
    format      ascii;
    arch        "LSB;label=32;scalar=64";
    class       volScalarField;
    location    "0";
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 257.15;
boundaryField
    protectedZone
        type            zeroGradient;
    waveFacing
        type            codedMixed;
        refValue        uniform 273.15;
        refGradient     uniform 0;
        valueFraction   uniform 0;
        source          uniform 0;
        value           uniform 267.5;
        name            preciceRobinByAlpha;
        codeInclude     #{
			#include "fvCFD.H"
        code            #{
			const fvPatch&              p     = this->patch();
			const label                 patchI= p.index();
			const fvMesh&               mesh  = p.boundaryMesh().mesh();
			// cache the convection parameters once
			static bool haveProps = false;
			static scalar hwAir(0), TwAir(273.15), hwWtr(0), TwWtr(273.15);
			if (!haveProps)
				IOdictionary tp
					IOobject
						"transportProperties",
						mesh.time().constant(),
						mesh,
						IOobject::MUST_READ,
						IOobject::NO_WRITE
				if (tp.found("convectionProperties"))
					const dictionary& conv = tp.subDict("convectionProperties");
					if (conv.found("airExposedZone"))
						const dictionary& airD = conv.subDict("airExposedZone");
						hwAir = dimensionedScalar("hw", dimPower/dimArea/dimTemperature, airD).value();
						TwAir = dimensionedScalar("Tw", dimTemperature,                    airD).value();
					else
						if (conv.found("hwAir")) hwAir = readScalar(conv.lookup("hwAir"));
						if (conv.found("TwAir")) TwAir = readScalar(conv.lookup("TwAir"));
					if (conv.found("waveImpactZone"))
						const dictionary& wtrD = conv.subDict("waveImpactZone");
						hwWtr = dimensionedScalar("hw", dimPower/dimArea/dimTemperature, wtrD).value();
						TwWtr = dimensionedScalar("Tw", dimTemperature,                  wtrD).value();
					else
						if (conv.found("hwWtr")) hwWtr = readScalar(conv.lookup("hwWtr"));
						if (conv.found("TwWtr")) TwWtr = readScalar(conv.lookup("TwWtr"));
				haveProps = true;
			// request needed fields (with safe fallback)
			const fvPatchScalarField* alphaPtr = nullptr;
			if (mesh.foundObject<volScalarField>("alphaWater"))
				const volScalarField& alphaVol = mesh.lookupObject<volScalarField>("alphaWater");
				alphaPtr = &alphaVol.boundaryField()[patchI];
			// Thermal conductivity on patch, else fallback to 1.0
			scalarField kappa(p.size(), 1.0);
			if (mesh.foundObject<volScalarField>("Kth"))
				const volScalarField& Kth = mesh.lookupObject<volScalarField>("Kth");
				const fvPatchScalarField& Kp = Kth.boundaryField()[patchI];
				kappa = Kp; // copy values from the field
			const scalarField& invDelta = p.deltaCoeffs();// Geometric factor
			// 3) create mixed coefficients (Robin by alpha)
			this->refValue()      = scalarField(p.size(), 0.0);
			this->refGrad()       = scalarField(p.size(), 0.0);
			this->valueFraction() = scalarField(p.size(), 0.0);
			const scalar thr = 0.5;          // VOF interface
			forAll(this->refValue(), fI)
				bool wet = false;
				if (alphaPtr) wet = ((*alphaPtr)[fI] > thr);
				const scalar h    = wet ? hwWtr : hwAir;
				const scalar Tinf = wet ? TwWtr : TwAir;
				// Mixed-BC Dirichlet weight for Robin: A = h / (h + kappa * (1/delta))
				const scalar A = h / (h + kappa[fI]*invDelta[fI] + SMALL);
				this->refValue()[fI]      = Tinf;    // Dirichlet target
				this->refGrad()[fI]       = 0.0;     // Neumann part (unused here)
				this->valueFraction()[fI] = A;       // 0 -> Neumann; 1 -> Dirichlet
        codeOptions     #{
			-I$(LIB_SRC)/finiteVolume/lnInclude
    top
        type            externalWallHeatFluxTemperature;
        mode            coefficient;
        h               uniform 5;
        Ta              uniform 291.94;
        kappaMethod     lookup;
        kappa           Kth;
        value           uniform 273.15;
    bottom
        type            fixedValue;
        value           uniform 253.15;
    backSurface
        type            fixedValue;
    frontAndBack
        type            empty;
    erodedWall
        type            codedMixed;
        refValue        nonuniform List<scalar> 0();
        refGradient     nonuniform List<scalar> 0();
        valueFraction   nonuniform List<scalar> 0();
        source          nonuniform List<scalar> 0();
        value           nonuniform List<scalar> 0();
        name            robinByAlpha_erodedWall;
        codeInclude     #{
			#include "fvCFD.H"
        code            #{
			// Early exit if patch is still empty
			if (p.size() == 0)
				return;
			const label patchI = p.index();
			if (!haveProps)
				IOdictionary tp
					IOobject
						mesh,
						IOobject::NO_WRITE
					else
					else
				haveProps = true;
			// Get required fields (with safe fallback)
				kappa = Kp;
			// Build mixed coefficients (Robin by alpha) SAFETY CHECK: ensure arrays are sized correctly
			if (this->refValue().size() != p.size())
				this->refValue().setSize(p.size(), 273.15);
				this->refGrad().setSize(p.size(), 0.0);
				this->valueFraction().setSize(p.size(), 0.5);
				bool wet = false;
        codeOptions     #{
precice_config.xml (1.4 KB)
Looking forward to your suggestions. Thank you.
This is not currently possible to handle with the OpenFOAM adapter as-is and it is only recently that the core library added support for dynamic meshes:
I opened an issue for adding support for remeshing in the OpenFOAM adapter, let’s collect any helpful details there:
How does olaFlow modify the mesh? Does it use a standard OpenFOAM functionality?
For now, what you could do as a workaround, would be to use the regular ALE approach for the ablation restart the simulation every few timesteps, which would by definition update the coupling interface mesh.
Hi, long threads are always welcome!
I’ll meet with @Makis next week, and we try to come up with a prototype adapter.
There are now enough loud voices needing this in the adapter that we will be actively looking into it.
Thank you @Makis for committing to solutions in this respect and for the suggested alternatives. And, yes, olaFlow uses the standard OpenFOAM functionality for mesh modifications.
Thank you for committing to this. I can’t wait! There are a lot of multiphysics simulations that will be done once we have this functionality in place.
Could please point us to an example/tutorial that we could use as starting point for olaFlow with mesh refinement?
As far as I know, olaFlow’s dynamic mesh implementation is on the inlet side of a typical waveflume for simulating wavemaker movements olaFlow/tutorials/wavemakerFlume at master · phicau/olaFlow · GitHub. In my case, I am coupling the outlet patch to an external (OpenFOAM) solver. I pushed some files here: https://github.com/Omonigbehin/thermalFoam
