Hello all,
I’m trying to install Calculix and Precice to run FSI simulation with OpenFoam. I’ve been following these instructions (https://www.youtube.com/watch?v=U0RuGXiLvrs). At 17:12, he mentions to go in .local/bin however I get no such file or directory.
Basically I’m stuck on the create PATH part.
If anyone could help me that would be appreciated. I’m on ubuntu 20.04.6 LTS
I was using Linux on WSL. I’ve seen gone another path and install ubuntu on a virtual machine with VMware. I’m getting a different error this time. I’ll start another thread to not confuse it for future reader
I’ve also try what your suggesting but it doesn’t work for me. I forgot the exact error but it saying access denied to something. I know you can’t help me without the error code but just wanted to let you know.
I’m lost here. I tried it again and I don’t get any error but it doesn’t install
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Note, selecting 'calculix-precice2' instead of './calculix-precice2_2.20.0-1_amd64_jammy.deb'
calculix-precice2 is already the newest version (2.20.0-1).
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Your Ubuntu version is 20.04, which has the name “Focal Fossa”. You are trying to install a package for jammy, i.e., “Jammy Jellyfish”, 22.04. This is just the Ubuntu convention.
What this is telling you later, is that you already have the package installed:
Which means that if you run ccx_preCICE, you should get this message:
