I have been having trouble when I follow the adapter download and build guidelines on the site for preCICE v3.1.2, where I get the same problem as:
CalculiX adapter installation - #4 by IshaanDesai
however, I am a beginner at linux and I can’t seem to install this file
using the command /CalculiX# sudo apt install ./calculix-precice3_2.20.1-2_amd64_jammy.deb
Can anyone tell me how to go about installing the adapter of this new version so that I don’t get ccx_preCICE error?
Edit 1:
This is the exact problem I have when I run this command, however I have already installed preCICE in the directory before calculix and while running tutorial cases, openfoam adapter runs perfectly fine with that preCICE library
