Configuration of the Multiple Perpendicular Flaps tutorial case
I’m just curious to clarify one thing I saw now in the precice configuration file from the multiple flaps tutorial case.
Why are we creating 2 Fluid mesh here… Even though we have a single fluid participant.
    <mesh name="Fluid1-Mesh-Centers">
      <use-data name="Stress1" />
    </mesh>
    <mesh name="Fluid1-Mesh-Nodes">
      <use-data name="Displacement1" />
    </mesh>
    <mesh name="Fluid2-Mesh-Centers">
      <use-data name="Stress2" />
    </mesh>
    <mesh name="Fluid2-Mesh-Nodes">
      <use-data name="Displacement2" />
    </mesh>
    <mesh name="Solid1-Mesh">
    </mesh>
    <mesh name="Solid2-Mesh">
    </mesh>
Hi @pranavd,
these meshes are the interface meshes. This case has two interfaces: one between Fluid and Solid1 (the upstream flap), and one between Fluid and Solid2 (the downstream flap).
Is that clear? Feel free to dig deeper.
Hi @Makis ,
Thanks for looking into this :). Lets assume a case
Maybe like this…
So here do i need to create a interface mesh for Solid-Solid Interaction too?
Is it like do we need a interface for same phase interactions? Or can the solver take this into account automatically…
If the two solids are touching each other, then I am not sure. I don’t have any experience with modelling contacts.
In principle, yes, you would need to also define an interface (and everything else) for the solid-solid interaction. But expect issues, since this is something now yet commonly done with preCICE. I expect at least the sliding meshes to be an issue (see also FSI with CalculiX explicit solver and sliding contact).
Thank you, going to try and simulate this kind of case soon. Will update you about the result at least in personal if this topic is closed.
