I found that in the official PreCICE case, compressible solvers were rarely used. If I want to use the compressibleInterDyMFoam solver, how should I modify the fvSchemes and fvSolution files? I tried to modify the fvSchemes and fvSolution files in interFoam in the breaking-dam-2d example, but I kept reporting errors.
Some examples that might help:
- buoyantPimpleFoam: Flow over heated plate | preCICE - The Coupling Library
- sonicLiquidFoam: Partitioned pipe flow | preCICE - The Coupling Library
- interFoam: Partitioned pipe two phase | preCICE - The Coupling Library
They can definitely be improved and your solver is different (and probably old, given the DyM in the name), but might lead somewhere.
Does the uncoupled fluid case work?
