CMake isn't picking up on the correct PETSc version
I am compiling from source.
  • preCICE version: master branch
  • Operating system: “Ubuntu 20.04”
  • Installation method: from source and using cmake
  • Dependency versions: PETSc from master
I run cmake with PETSc feature on and I get this error:
CMake Error at /usr/share/cmake-3.22/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
  Could NOT find PETSc: Found unsuitable version "", but required is at least
  "3.15" (found FALSE)
  /usr/share/cmake-3.22/Modules/FindPackageHandleStandardArgs.cmake:592 (_FPHSA_FAILURE_MESSAGE)
  cmake/modules/FindPETSc.cmake:85 (find_package_handle_standard_args)
  CMakeLists.txt:235 (find_package)
I did export petsc following the precice docs with:
export PETSC_DIR=/home/abbas/precice/petsc
export PETSC_ARCH=arch-linux-c-opt
export LD_LIBRARY_PATH=$PETSC_DIR/$PETSC_ARCH/lib:$LD_LIBRARY_PATH
It doesn’t seem like the actual petsc version is being read.
Any help?
terminal.txt (4.4 KB)
I assume that this code from the master branch does not contain any version information, that’s why CMake reports that it found something, but the version is just an empty string.
Try installing a released version, instead.
Exporting only the library is not enough, preCICE needs additionally the header files (which also contain the version information).
You could also try to use pkg config for this purpose:
export PKG_CONFIG_PATH=$PETSC_DIR/$PETSC_ARCH/lib/pkgconfig:$PKG_CONFIG_PATH
Where this path should contain petsc.pc or export the headers manually.
Thanks Gerasimos and David,
I tried both of your recommendations and with a release version of precise but I keep getting the same error.
I don’t know if this is relevant but I configured another project with petsc not too long ago with the same export commands and things worked well. I also don’t know if this is relevant either but I have a main directory called PRECICE and inside it I have precise, petsc, eigen, and a build directory I want to build precise in. Any hints?
Since v3, preCICE uses pkg-config to locate PETSc, so it’s easiest to start from there.
  1. Use pkg-config --modversion PETSc to see what version pkg-config can find. If this fails, then you need to modify PKG_CONFIG_PATH or fix the PETSc installation.
  2. Then check PKG_CONFIG_SYSTEM_INCLUDE_PATH=1 pkg-config --cflags PETSc to see if the paths are correct
  3. Then check PKG_CONFIG_SYSTEM_LIBRARY_PATH=1 pkg-config --libs PETSc to see if the -L paths are correct.
  4. Delete CMakeCache.txt in the binary/build directory and try again.
Also note that (unless something changed recent) if you use a --prefix to configure PETSc, then the pkg-config files will only work when you install PETSc.
If you don’t specify a prefix, then pkg-config files only work from the build directory.
Also, is there any reason you don’t use petsc-real-dev from the Ubuntu repos?
Hi @fsimonis
When I tried to install precice with petsc in cluster, I receive warning and errors like:
[  0%] Built target GitRevision
[  0%] Linking CXX static library libfmtlib-static.a
[  0%] Built target fmtlib-static
[  0%] Building CXX object CMakeFiles/preciceCore.dir/src/precice/impl/versions.cpp.o
[  1%] Building CXX object CMakeFiles/preciceCore.dir/src/acceleration/Acceleration.cpp.o
[  0%] Building CXX object CMakeFiles/preciceCore.dir/src/acceleration/AitkenAcceleration.cpp.o
[  1%] Building CXX object CMakeFiles/preciceCore.dir/src/acceleration/ConstantRelaxationAcceleration.cpp.o
[  1%] Building CXX object CMakeFiles/preciceCore.dir/src/acceleration/IQNILSAcceleration.cpp.o
[  1%] Building CXX object CMakeFiles/preciceCore.dir/src/acceleration/config/AccelerationConfiguration.cpp.o
[  1%] Building CXX object CMakeFiles/preciceCore.dir/src/acceleration/impl/ConstantPreconditioner.cpp.o
[  2%] Building CXX object CMakeFiles/preciceCore.dir/src/acceleration/impl/ParallelMatrixOperations.cpp.o
[  2%] Building CXX object CMakeFiles/preciceCore.dir/src/acceleration/BaseQNAcceleration.cpp.o
[  2%] Building CXX object CMakeFiles/preciceCore.dir/src/acceleration/IQNIMVJAcceleration.cpp.o
cc1plus: warning: command line option ‘-std=c99’ is valid for C/ObjC but not for C++
/public/home/chenshunhua/local/petsc/include/petscvec.h: In function ‘PetscErrorCode VecCUDAReplaceArray(Vec, const PetscScalar*)’:
/public/home/chenshunhua/local/petsc/include/petscvec.h:1002:1: error: ‘PETSC_FUNCTION_NAME_CXX’ was not declared in this scope; did you mean ‘PETSC_FUNCTION_NAME_C’?
 1002 | VEC_CUDA_DECL_OR_STUB(PetscErrorCode VecCUDAReplaceArray(Vec a, const PetscScalar b[]), (void)a, (void)b)
/public/home/chenshunhua/local/petsc/include/petscvec.h: In function ‘PetscErrorCode VecHIPReplaceArray(Vec, const PetscScalar*)’:
/public/home/chenshunhua/local/petsc/include/petscvec.h:1003:1: error: ‘PETSC_FUNCTION_NAME_CXX’ was not declared in this scope; did you mean ‘PETSC_FUNCTION_NAME_C’?
 1003 | VEC_HIP__DECL_OR_STUB(PetscErrorCode VecHIPReplaceArray(Vec a, const PetscScalar b[]), (void)a, (void)b)
/public/home/chenshunhua/local/petsc/include/petscvec.h: In function ‘PetscErrorCode VecCUDAResetArray(Vec)’:
/public/home/chenshunhua/local/petsc/include/petscvec.h:1005:1: error: ‘PETSC_FUNCTION_NAME_CXX’ was not declared in this scope; did you mean ‘PETSC_FUNCTION_NAME_C’?
 1005 | VEC_CUDA_DECL_OR_STUB(PetscErrorCode VecCUDAResetArray(Vec a), (void)a)
/public/home/chenshunhua/local/petsc/include/petscvec.h: In function ‘PetscErrorCode VecHIPResetArray(Vec)’:
/public/home/chenshunhua/local/petsc/include/petscvec.h:1006:1: error: ‘PETSC_FUNCTION_NAME_CXX’ was not declared in this scope; did you mean ‘PETSC_FUNCTION_NAME_C’?
 1006 | VEC_HIP__DECL_OR_STUB(PetscErrorCode VecHIPResetArray(Vec a), (void)a)
What’s the problem of this?
This is a question for PETSc devs, but as far as I can tell, this means that PETSc was configured without C++. So either --with-cxx=0, with an invalid C++ compiler, or it wasn’t able to find a working C++ compiler.
https://petsc.org/release/install/install/#compilers
Thank you so much :blush:!
I couldn’t get it to work compiling petsc from source so I installed petsc dev and precice seems to copile now.
First time I installed petsc I did it that way so I got into the habit of compiling petsc from source.
Now I don’t want to installed petsc-dev because I am afraid that it will interfere with my other builds.
In general, using system libraries consistently will lead to less guess work and less problems.
I would always advise to use system libraries unless you really need a newer version.
