I’m successfully building and using the OpenFOAM adapter. It works great. It works so well, I want to make it available for other people at my company to use it. When I build the adapter it is automatically put in $FOAM_USER_LIBBIN
, which is in a location on our file system that only I can access. I don’t see anything wrong with simply moving libpreciceAdapterFunctionObject.so
to $FOAM_LIBBIN
, which is in a location that all users on the filesystem can access. Can anyone see any issues with this before I just try it?
There shouldn’t be any issue with that. We use FOAM_USER_LIBBIN
because this is typically user-writable, so it is a good default. It is not hard-coded anywhere apart from the Allwmake
file and we don’t depend on any dependency expected there.
