When the volume coupling case of the old version is replicated in the new version adapter, the data does not match during the writing process
my system:Ubuntu 22.04.4 LTS
preCICE:v1.3.1
openfoamv2006
new version:openfoam_adapter-1.3.1
old version: arpans16/openfoam-adapter-volCoup: 为精确的 openfoam 适配器添加体积耦合器 - 个人作品 — arpans16/openfoam-adapter-volCoup: Adding volumetric coupling to the precice openfoam adapter - personal work (github.com)
The old version of the adapter added an AITS module and two Locationtype_: volume and volsurf to achieve volume coupling, and provided tutorials for verification, I successfully added the AITS module and two Locationtype_: volume and volsurf in the new version, and the compilation was successful. But when I run the original tutorials, I get the precice error:
ERROR: Input sizes are inconsistent attempting to write 3D data “Velocity” to mesh “flowSolve-Mesh-vol”. You passed 36707 vertices and 38043 data components, but we expected 110121 data components (3 x 36707).
All the data exchanged in my run case is similar to the speed, I added some debugging information to the write function in the AITS/VelocityAIT.C file and the writeCouplingData function in Interface.C, and here’s the detailed output information:
---[preciceAdapter] [DEBUG] Writing data for Velocity
---[preciceAdapter] [DEBUG] Number of vertices: 36707
---[preciceAdapter] [DEBUG] Total number of cells: 12013
---[preciceAdapter] [DEBUG] Mesh dimension: 3
---[preciceAdapter] [DEBUG] Write: first value of U at bufferIndex: 0 is 0.000000
---[preciceAdapter] [DEBUG] Processing cell 0, bufferIndex: 0
---[preciceAdapter] [DEBUG] Processing cell 1000, bufferIndex: 3000
---[preciceAdapter] [DEBUG] Processing cell 2000, bufferIndex: 6000
---[preciceAdapter] [DEBUG] Processing cell 3000, bufferIndex: 9000
---[preciceAdapter] [DEBUG] Processing cell 4000, bufferIndex: 12000
---[preciceAdapter] [DEBUG] Processing cell 5000, bufferIndex: 15000
---[preciceAdapter] [DEBUG] Processing cell 6000, bufferIndex: 18000
---[preciceAdapter] [DEBUG] Processing cell 7000, bufferIndex: 21000
---[preciceAdapter] [DEBUG] Processing cell 8000, bufferIndex: 24000
---[preciceAdapter] [DEBUG] Processing cell 9000, bufferIndex: 27000
---[preciceAdapter] [DEBUG] Processing cell 10000, bufferIndex: 30000
---[preciceAdapter] [DEBUG] Processing cell 11000, bufferIndex: 33000
---[preciceAdapter] [DEBUG] Processing cell 12000, bufferIndex: 36000
---[preciceAdapter] [DEBUG] Final bufferIndex: 38043
---[preciceAdapter] [DEBUG] Number of written data components: 38043
---[preciceAdapter] [DEBUG] Expected number of data components: 110121
--> FOAM FATAL ERROR:
Error in the preCICE adapter:
Mismatch in written data size for Velocity. Expected: 110121, Actual: 38043
in file Utilities.C at line 32.
FOAM exiting
Looking for any time directories without results (e.g. stray functionObjectProperties files, see openfoam-adapter issue #26 on GitHub)…
New statement:
The old version adapter added an AITS module and two Locationtype_:volume and volsurf to implement volume coupling, and provided tutorials for verification. I successfully added the AITS module and two Locationtype_:volume and volsurf in the new adapter version, and compiled successfully, but when I ran the original tutorials, I encountered the following error (all the data exchanged in the case I ran was similar to velocity, and I used the new version adapter’s Locationtype_:volumeCentre and the old version adapter’s Locationtype_:volume and volsurf, and all had the same error):
tlk@tlk-virtual-machine:~/OpenFOAM/tlk-v2006/run/openfoam-adapter-1.3.1_ooo/try/volCoup-oneWay/flowSolve$ ./run.sh
wmake ../../solvers/flowSolveFoam
g++ -std=c++11 -m64 -pthread -DOPENFOAM=2006 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas  -O3  -DNoRepository -ftemplate-depth-100 -I/home/tlk/OpenFOAM/OpenFOAM-v2006/src/finiteVolume/lnInclude -I/home/tlk/OpenFOAM/OpenFOAM-v2006/src/meshTools/lnInclude -I/home/tlk/OpenFOAM/OpenFOAM-v2006/src/sampling/lnInclude -I/home/tlk/OpenFOAM/OpenFOAM-v2006/src/transportModels/compressible/lnInclude -I/home/tlk/OpenFOAM/OpenFOAM-v2006/src/thermophysicalModels/basic/lnInclude -I/home/tlk/OpenFOAM/OpenFOAM-v2006/src/thermophysicalModels/radiation/lnInclude -I/home/tlk/OpenFOAM/OpenFOAM-v2006/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/tlk/OpenFOAM/OpenFOAM-v2006/src/TurbulenceModels/compressible/lnInclude -iquote. -IlnInclude -I/home/tlk/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude -I/home/tlk/OpenFOAM/OpenFOAM-v2006/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed  Make/linux64GccDPInt32Opt/flowSolveFoam.o -L/home/tlk/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib \
    -lfiniteVolume -lfvOptions -lmeshTools -lsampling -lcompressibleTransportModels -lfluidThermophysicalModels -lradiationModels -lspecie -lturbulenceModels -lcompressibleTurbulenceModels -latmosphericModels -lOpenFOAM -ldl  \
     -lm -o /home/tlk/OpenFOAM/tlk-v2006/platforms/linux64GccDPInt32Opt/bin/flowSolveFoam
Preparing and running the flowSolve participant...
| \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \\    /   O peration     | Version:  v2006                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
|    \\/     M anipulation  |                                                 |
Build  : v2006 OPENFOAM=2006
Arch   : "LSB;label=32;scalar=64"
Exec   : blockMesh
Date   : Oct 09 2024
Time   : 22:42:58
Host   : tlk-virtual-machine
PID    : 20745
I/O    : uncollated
Case   : /home/tlk/OpenFOAM/tlk-v2006/run/openfoam-adapter-1.3.1_ooo/try/volCoup-oneWay/flowSolve
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
Create time
Creating block mesh from "system/blockMeshDict"
Creating block edges
No non-planar block faces defined
Creating topology blocks
Creating topology patches
Creating block mesh topology
--> FOAM Warning :
    From Foam::polyMesh::polyMesh(const Foam::IOobject&, Foam::pointField&&, const cellShapeList&, const faceListList&, const wordList&, const Foam::PtrList<Foam::dictionary>&, const Foam::word&, const Foam::word&, bool)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 915
    Found 6 undefined faces in mesh; adding to default patch defaultFaces
Check topology
	Basic statistics
		Number of internal faces : 2
		Number of boundary faces : 14
		Number of defined boundary faces : 14
		Number of undefined boundary faces : 0
	Checking patch -> block consistency
Creating block offsets
Creating merge list (topological search)...
Creating polyMesh from blockMesh
Creating patches
Creating cells
Creating points with scale 1
    Block 0 cell size :
        i : 0.0123864236173 .. 0.00247728472346
        j : 0.00232699027775 .. 0.0349048541662
        k : 0.4 .. 0.4
    Block 1 cell size :
        i : 0.0024958960536 .. 0.012479480268
        k : 0.4 .. 0.4
    Block 2 cell size :
        i : 0.0392156862745 .. 0.0392156862745
        k : 0.4 .. 0.4
There are no merge patch pairs
Writing polyMesh with 0 cellZones
Mesh Information
  boundingBox: (-0.5 0 0) (3 0.5 0.4)
  nPoints: 24696
  nCells: 12013
  nFaces: 48386
  nInternalFaces: 23692
Patches
  patch 0 (start: 23692 size: 41) name: inlet
  patch 1 (start: 23733 size: 41) name: outlet
  patch 2 (start: 23774 size: 293) name: top
  patch 3 (start: 24067 size: 81) name: slip-bottom
  patch 4 (start: 24148 size: 51) name: bottom
  patch 5 (start: 24199 size: 161) name: interface
  patch 6 (start: 24360 size: 24026) name: defaultFaces
End
Exec   : checkMesh
Date   : Oct 09 2024
Time   : 22:42:59
PID    : 20747
I/O    : uncollated
nProcs : 1
Create time
Create mesh for time = 0
Time = 0
Mesh stats
    internal points:  0
    faces:            48386
    internal faces:   23692
    cells:            12013
    faces per cell:   6
    boundary patches: 7
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     12013
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    inlet               41       84       ok (non-closed singly connected)
    outlet              41       84       ok (non-closed singly connected)
    top                 293      588      ok (non-closed singly connected)
    slip-bottom         81       164      ok (non-closed singly connected)
    bottom              51       104      ok (non-closed singly connected)
    interface           161      324      ok (non-closed singly connected)
    defaultFaces        24026    24696    ok (non-closed singly connected)
Checking faceZone topology for multiply connected surfaces...
    No faceZones found.
Checking basic cellZone addressing...
    No cellZones found.
Checking geometry...
    Overall domain bounding box (-0.5 0 0) (3 0.5 0.4)
    Mesh has 2 geometric (non-empty/wedge) directions (1 1 0)
    Mesh has 2 solution (non-empty) directions (1 1 0)
    All edges aligned with or perpendicular to non-empty directions.
    Boundary openness (-5.95502088768e-18 -1.17546934044e-16 -2.36226616626e-16) OK.
    Max cell openness = 2.13849956364e-16 OK.
    Max aspect ratio = 16.8525355069 OK.
    Minimum face area = 5.76461746671e-06. Maximum face area = 0.015686274512.  Face area magnitudes OK.
    Min volume = 2.30584698668e-06. Max volume = 0.000547527124249.  Total volume = 0.7.  Cell volumes OK.
    Mesh non-orthogonality Max: 0 average: 0
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 5.82550106883e-14 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
Exec   : flowSolveFoam
Date   : Oct 09 2024
Time   : 22:43:00
PID    : 20752
I/O    : uncollated
nProcs : 1
Create time
PIMPLE: Operating solver in PISO mode
Reading thermophysical properties
Selecting thermodynamics package
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState rhoConst;
    specie          specie;
    energy          sensibleEnthalpy;
--> FOAM Warning :
    From bool Foam::GeometricField<Type, PatchField, GeoMesh>::readIfPresent() [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
    in file /home/tlk/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude/GeometricField.C at line 108
    read option IOobject::MUST_READ or MUST_READ_IF_MODIFIED suggests that a read constructor for field rho would be more appropriate.
Reading field U
Creating field Dpdt
Creating turbulence model
Reading g
Reading hRef
Calculating field g.h
Reading field p_rgh
Creating field dpdt
Creating field kinetic energy K
No MRF models present
Radiation model not active: radiationProperties not found
Selecting radiationModel none
Courant Number mean: 0 max: 0
Starting time loop
---[preciceAdapter] Loaded the OpenFOAM-preCICE adapter - v1.3.1.
SolverType: ||1---[precice]  This is preCICE version 3.1.1
---[precice]  Revision info: no-info [git failed to run]
---[precice]  I am participant "flowSolve"
---[preciceAdapter] Internal faces = 23692
---[preciceAdapter] Patch size = 7
---[preciceAdapter] Boundary faces = 24694
---[precice]  Primary ranks are connected
---[precice]  Setting up preliminary secondary communication to coupling partner/s
---[precice]  Prepare partition for mesh flowSolve-Mesh-vol
---[precice]  Gather mesh flowSolve-Mesh-vol
---[precice]  Send global mesh flowSolve-Mesh-vol
---[precice]  Prepare partition for mesh flowSolve-Mesh-volSurf
---[precice]  Gather mesh flowSolve-Mesh-volSurf
---[precice]  Send global mesh flowSolve-Mesh-volSurf
---[precice]  Setting up secondary communication to coupling partner/s
---[precice]  Secondary ranks are connected
---[precice]  iteration: 1, time-window: 1, time: 0 of 10, time-window-size: 0.01, max-time-step-size: 0.01, ongoing: yes, time-window-complete: no,
---[preciceAdapter] preCICE was configured and initialized
---[preciceAdapter] [DEBUG] Writing data for interface 0
---[preciceAdapter] [DEBUG] Writing data for interface 1
---[preciceAdapter] Setting the solver's endTime to infinity to prevent early exits. Only preCICE will control the simulation's endTime. Any functionObject's end() method will be triggered by the adapter. You may disable this behavior in the adapter's configuration.
Time = 0.01
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
PIMPLE: iteration 1
DILUPBiCGStab:  Solving for Ux, Initial residual = 1, Final residual = 7.78951375942e-08, No Iterations 2
DILUPBiCGStab:  Solving for Uy, Initial residual = 1, Final residual = 2.6959134457e-07, No Iterations 2
DICPCG:  Solving for p_rgh, Initial residual = 0.815645845211, Final residual = 0.00751038250855, No Iterations 89
time step continuity errors : sum local = 6.87802874908e-05, global = -1.0849523174e-05, cumulative = -1.0849523174e-05
DICPCG:  Solving for p_rgh, Initial residual = 0.309794817979, Final residual = 8.7469094214e-09, No Iterations 215
time step continuity errors : sum local = 2.43039149227e-10, global = 3.24487586703e-13, cumulative = -1.08495228495e-05
ExecutionTime = 0.77 s  ClockTime = 3 s
---[precice] ERROR:  Input sizes are inconsistent attempting to write 3D data "Velocity" to mesh "flowSolve-Mesh-vol". You passed 36707 vertices and 38043 data components, but we expected 110121 data components (3 x 36707).
Please use triple backticks ``` around big logs to improve readability.
The error message you encounter means that the adapter does not provide the correct amount of data for the amount of vertices.
Example for the error in the last post:
Meaning, preCICE expects 3d vectorial data for 36707 vertices provided by the adapter.
This should result in 3 * 36707 = 110121 data components, but the adapter only passes 38043.
The passed amount of data suggests that this is data for only 38043 / 3 = 12681 vertices.
Therefore, this is either a bug in the OpenFOAM adapter @Makis, or the solver you are using is performing some kind of mesh refinement/coarsening that leads to this difference, which is unsupported.
Best
Frédéric
Hi
Can you explain the solution in more detail, I still don’t understand it now, I can probably know that there is an error when the adapter passes data to preCICE, but at the moment I don’t have the idea of how to locate the specific error and solve it so that it can run normally under the new adapter version
Output when running tutorials:
Exec   : blockMesh
Date   : Oct 10 2024
Time   : 23:09:22
PID    : 23374
I/O    : uncollated
nProcs : 1
Create time
--> FOAM Warning :
Check topology
	Basic statistics
Creating patches
Creating cells
    Block 0 cell size :
        k : 0.4 .. 0.4
    Block 1 cell size :
        k : 0.4 .. 0.4
    Block 2 cell size :
        k : 0.4 .. 0.4
Mesh Information
  nPoints: 24696
  nCells: 12013
  nFaces: 48386
Patches
End
Exec   : checkMesh
Date   : Oct 10 2024
Time   : 23:09:23
PID    : 23398
I/O    : uncollated
nProcs : 1
Create time
Time = 0
Mesh stats
    internal points:  0
    faces:            48386
    cells:            12013
    faces per cell:   6
    boundary patches: 7
    point zones:      0
    face zones:       0
    cell zones:       0
    hexahedra:     12013
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
    Point usage OK.
    Face vertices OK.
    No faceZones found.
    No cellZones found.
    Face pyramids OK.
Mesh OK.
End
Date   : Oct 10 2024
Time   : 23:09:25
PID    : 23408
I/O    : uncollated
nProcs : 1
Create time
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
--> FOAM Warning :
Reading field U
Creating field Dpdt
Reading g
Reading hRef
Reading field p_rgh
Creating field dpdt
Starting time loop
Time = 0.01
PIMPLE: iteration 1
ExecutionTime = 1.14 s  ClockTime = 4 s
Looking for any time directories without results (e.g. stray functionObjectProperties files, see openfoam-adapter issue #26 on GitHub)...
@mr.junfu444 I understand that previously, you were using the (very old) modified adapter from the AIT, which first added support for volume coupling. I guess you then ported that adapter to preCICE v3 by yourself.
Note 1: The official OpenFOAM adapter v1.3.0 and later now supports volume coupling out-of-the-box. You don’t need that old branch anymore.
Note 2: These are the instructions for porting an adapter to v3: Porting from 2.x to 3.x | preCICE - The Coupling Library
A starting point to figure out what might be different in your porting regarding the number of locations to read/write to:
And another clue: are you maybe mixing up scalar and vector fields?
I understand this is too long since you asked: have you already found a solution? If yes, what was the issue?
