I have 4 questions regarding: Step 6 – Implicit coupling (Step 6 – Implicit coupling | preCICE - The Coupling Library)
(I use the two figures from your website to describe my questions. One figure is the “Fixed time window” in Step 5 – Non-matching timestep sizes. The other figure is the pseudo-code in Step 6 – Implicit coupling)
My 1st question is about the condition “if(precice.isActionRequired(coric)){ // timestep not converged”:
What will cause this condition to be TRUE?
My understanding is that it can be TRUE only when ADVANCE checks the convergence when time is at t^(n+1).
If the convergence is not satisfied, this time window is failed and precice will try to redo the time window t^n→t^(n+1), so reloadOldState().
My 2nd question is if this condition is FALSE, why does precice endTimeStep()?
If solver A does subcycle and just finishes τ^(k-1), (we still need march τ^k to reach t^(n+1)), ADVANCE shouldn’t check convergence yet, so FALSE.
Then we enter this ELSE branch to endTimeStep(). But we should ask solver A to do τ^k instead of endTimeStep(), right?
My 3rd question is if timestep not converged, what will precice do to make it converge when redo the time window with reloadOldState()?
My understanding is that reloadOldState() will restart from the status at t^n, right?
Some background is that:
For my implicit solver, it is based on a Newton-Raphson loop to solve each τ^(k-1).
If my implicit solver can’t converge for τ^(k-1), what it does is to reduce τ^(k-1) to a smaller time increment, for example 0.25*τ^(k-1) to retry.
Basically, my implicit solver retry the Newon loop with a smaller time increment to linearize the nonlinear problem if it is highly nonlinear.
We call this reduction of time increment size a cutback. The trade-off is we needs more number of time increments to solve the whole problem.
But it appears precice can’t use such a method because can be only either fixed or first-participant.
If my implicit solver reduces each τ^(k-1) (or in another words, my implicit solver increases the number of subcycles from t^n→t^(n+1)), is this a recommended way to redo the time window t^n→t^(n+1)?
If time window is small like t^(n+1)-t^n< τ^(k-1), my implicit solver should use the time increment size of t^(n+1)-t^n instead of its own τ^(k-1).
If here my implicit solver can’t converge, it will reduce to 0.25(t^(n+1)-t^n) to retry, then my implicit solver will enter subcycling too.
My last question is for both functions precice.readBlockVectorData and precice.writeBlockVectorData.
Why don’t we put them under “if (precice.isReadDataAvailable())” and “if (precice.isWriteDataRequired(dt))” as in “Step 5 – Non-matching timestep sizes”.
My answer is that they are dummy here, meaning these two won’t have any effect on the results because they will be exchanged/refreshed only in ADVANCE when time reaches t^(n+1).
Thanks a lot in advance.
Best
Hongwu
