Dear community members,
I have coupled my immersed boundary method program with calculix. After testing, my Perpendicular flap example has the same results as the official openFoam provided. However, I used a loose coupling strategy, which is an explicit strategy. Because the density ratio of this problem is relatively large, even the explicit strategy can obtain good results.
However, I encountered difficulties when reproducing the Turek Hron FSI3 example. Because the density ratio is 1, implicit coupling must be used. However, it has been impossible to reach convergence.
I compared the forces on the solid when calculated by the separate fluid solver(no fsi), and the results were correct.
I suspect that there is an error in the saving and reloading states function. I am showing the code of my program. Can anyone tell me which variables need to be saved? I have saved all variables as much as possible. Is this correct? If the reloading is to the original state, why does the force and displacement change? How is implicit coupling implemented?
Please help me, thank you!
