Undefined reference to get_mesh_vertices_and_ids_
(Moderator edit: Moved from Data Mapping and Immersed boundary method - #8, replying to @Le_mot )
Very excited to see this thread as I would also like to try the same job. Don’t know if you’ve done your idea, I’m currently facing a difficulty, because my fluid solver is in Fortran language, I used the precicef_get_mesh_vertices_and_IDs function when I want to get the mesh vertex coordinates and IDs, but when compiling, the compiler tells I get:
undefined reference to `precicef_get_mesh_vertices_and_ids_'
This is why, the version I use is precice 2.5.0. May I ask are you getting the grid position data for the solid directly, or are you using the displacement? In C++ code, using precice.getMeshVerticesAndIDs
I would appreciate it if you could share me your config file (precice-config.xml)
Thanks
In v2.5.0, the Fortran function is called precicef_get_mesh_vertices_and_IDs_.
This may be renamed or completely changed in preCICE v3.
Closing as duplicate of An error occurs when I want to access the mesh information directly - #2 by wufanxiaozi
