I want a fluid solver coupled to a solid solver for the Immersed Boundary Method. According to the official suggestion, I want to use this subroutine “precicef_get_mesh_vertices_and_IDs()” to get the vertex coordinates of the solid mesh, but I can’t find him when compiling. I saw that this function is still in the experimental stage and may be changed later, but I am using the latest version of precice, who can tell me whether this function has changed?
what should I do ? Can everyone help me!
No error is reported for other precice’s subroutine used, but when using this function,I received an error “undefined reference to `precicef_get_mesh_vertices_and_ids_'”
Thank you DavidSCN, I compiled and installed the source code on the supercomputing machine. The quickstart and Perpendicular flap in the tutorial can be run, and I can also successfully run the calculation examples in the provided Fortran binding.
Thank you David,Just now I compiled successfully, I don’t know where I modified, but it did succeed, thank you for your help. I also want to ask you a question, if I want to get the position of the solid mesh in the time loop, should I call the subroutine “precicef_get_mesh_vertices_and_IDs” in the time loop?
I have a new problem, I set it up according to the tutorial, but when I use subrountine “precicef_get_mesh_id(SolidMeshName, SolidMeshID)”, I get such an error message "preCICE:ERROR: The given Mesh ID “12395504” is unknown to preCICE .” Solid solver I used rigid_body_solver.cpp in quickstart, and modified it. I released the solid code and configuration files
fluid solver:
The error is “The given Mesh ID XXXX is unknown to preCICE”
Even if I change the code to CALL precicef_set_mesh_access_region(0, boundingBox)
still the same error.
I don’t know whether this command is necessary if I want to use “direct access to received meshes”.
When I comment out this line of code, initialization succeeds.
