Troubleshooting: Mixing up dependencies from system and Spack
In case you see that Spack reports an error in which points to a non-spack directory, maybe you are forcing your compiler to look at places it shouldn’t. Please avoid setting environment variables such as CPLUS_INCLUDE_PATH, LD_LIBRARY_PATH, or LIBRARY_PATH when using Spack. This can particularly lead to problems if you have a (broken) installation of a requested dependency in that path.
Keep in mind that, by default, Spack will use the default compiler of your system.
(this topic was only meant to move information here from the old preCICE wiki)
