Time step changing
I’m trying to change time step in preCICE / OpenFOAM and CalculiX but I’m find a error to simulate a case can you look for it please?
 iteration 1
 Using up to 1 cpu(s) for the energy calculation.
 Using up to 1 cpu(s) for spooles.
 average force= 15469129.249106
 time avg. forc= 1934082.949982
 largest residual force= 0.000001 in node 39 and dof 1
 largest increment of disp= 9.712185e+02
 largest correction to disp= 9.712185e+02 in node 38 and dof 1
 no convergence
 iteration 2
 largest residual force= 0.000000 in node 51 and dof 1
 largest correction to disp= 7.011653e-11 in node 63 and dof 1
 convergence
Adapter writing coupling data...
Writing DISPLACEMENTS coupling data with ID '2'.
Adapter calling advance()...
---[precice]  relative convergence measure: relative two-norm diff of data "Displacement" = 2.63e-02, limit = 5.00e-02, normalization = 4.01e+03, conv = true
---[precice]  relative convergence measure: relative two-norm diff of data "Force" = 5.17e-01, limit = 5.00e-02, normalization = 2.09e+08, conv = false
---[precice] ERROR:  Send using sockets failed with system error: write: Broken pipe
flap.inp (374 Bytes)
precice-config.xml (2.4 KB)
You need to change the end time in the precice-config AND in the calculix .inp file. (Probably too with the openfoam case)
I think you forgot one of these
I have the same end time in all files; you can check files above.
You have configured a step of 0.1 in both CalculiX and preCICE, but an end time of 5 in CalculiX and 1 in preCICE (Max-Time-Windows=10, and 10*0.1=1)
The number of time windows must not be confused with max-iterations, set to 50, which configures the number of iterations per time window in the context of implicit coupling.
