iteration 1
Using up to 4 cpu(s) for the stress calculation.
Using up to 4 cpu(s) for the energy calculation.
Using up to 4 cpu(s) for the symmetric stiffness/mass contributions.
Using up to 4 cpu(s) for spooles.
average force= 3.723656
time avg. forc= 0.002106
largest residual force= 79.709844 in node 128 and dof 1
largest increment of disp= 3.185859e-03
largest correction to disp= 3.185859e-03 in node 3351 and dof 1
no convergence
iteration 2
average force= 2.037328
time avg. forc= 0.001421
largest residual force= 35.937335 in node 128 and dof 1
largest correction to disp= 1.431355e-03 in node 3603 and dof 1
no convergence
iteration 3
average force= 322.350345
time avg. forc= 0.131471
largest residual force= 17013.257755 in node 143 and dof 2
largest increment of disp= 1.215580e-02
largest correction to disp= 1.215580e-02 in node 2922 and dof 1
no convergence
iteration 4
average force= 6.580589
time avg. forc= 0.003265
largest residual force= 31643.243215 in node 143 and dof 2
largest correction to disp= 1.064113e-02 in node 2922 and dof 1
corrupted double-linked list
[Hang-OUC:3595102] *** Process received signal ***
[Hang-OUC:3595102] Signal: Aborted (6)
[Hang-OUC:3595102] Signal code: (-6)
[Hang-OUC:3595102] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x14420)[0x7fdcbc379420]
[Hang-OUC:3595102] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xcb)[0x7fdcbbd7100b]
[Hang-OUC:3595102] [ 2] /lib/x86_64-linux-gnu/libc.so.6(abort+0x12b)[0x7fdcbbd50859]
[Hang-OUC:3595102] [ 3] /lib/x86_64-linux-gnu/libc.so.6(+0x8d266)[0x7fdcbbdbb266]
[Hang-OUC:3595102] [ 4] /lib/x86_64-linux-gnu/libc.so.6(+0x952fc)[0x7fdcbbdc32fc]
[Hang-OUC:3595102] [ 5] /lib/x86_64-linux-gnu/libc.so.6(+0x9594c)[0x7fdcbbdc394c]
[Hang-OUC:3595102] [ 6] /lib/x86_64-linux-gnu/libc.so.6(+0x95a7c)[0x7fdcbbdc3a7c]
[Hang-OUC:3595102] [ 7] /lib/x86_64-linux-gnu/libc.so.6(+0x96fe0)[0x7fdcbbdc4fe0]
[Hang-OUC:3595102] [ 8] /lib/x86_64-linux-gnu/libprecice.so.3(+0x2ce153)[0x7fdcbd0b8153]
[Hang-OUC:3595102] [ 9] /lib/x86_64-linux-gnu/libprecice.so.3(+0x2ac48d)[0x7fdcbd09648d]
[Hang-OUC:3595102] [10] /lib/x86_64-linux-gnu/libprecice.so.3(+0x261c38)[0x7fdcbd04bc38]
[Hang-OUC:3595102] [11] /lib/x86_64-linux-gnu/libprecice.so.3(+0x2d7338)[0x7fdcbd0c1338]
[Hang-OUC:3595102] [12] /lib/x86_64-linux-gnu/libprecice.so.3(+0x108d4f)[0x7fdcbcef2d4f]
[Hang-OUC:3595102] [13] /lib/x86_64-linux-gnu/libprecice.so.3(_ZN7precice11ParticipantD1Ev+0x249)[0x7fdcbcf116c9]
[Hang-OUC:3595102] [14] /lib/x86_64-linux-gnu/libprecice.so.3(+0xc2855)[0x7fdcbceac855]
[Hang-OUC:3595102] [15] /lib/x86_64-linux-gnu/libc.so.6(__cxa_finalize+0xce)[0x7fdcbbd74fde]
[Hang-OUC:3595102] [16] /lib/x86_64-linux-gnu/libprecice.so.3(+0x75077)[0x7fdcbce5f077]
[Hang-OUC:3595102] *** End of error message ***
./runparallel.sh:行 9: 3595102 已放弃 (核心已转储) ccx_preCICE -i flap -precice-participant Solid
Here’s my case file.
breaking-dam-ouhe(1).zip (5.6 MB)
Hi, it would help if you could also provide the log files from the solvers and from preCICE. And when you built the case based on the tutorial, which changes have you made?
fluid-openfoam-log.zip (2.3 MB)
solid-calculix-log.zip (595.1 KB)
